Author Topic: gold wing swap  (Read 896 times)
Offline MJL
  • Don't listen to me, I'm no
gold wing swap
« on: June 26, 2009, 01:17:23 PM »
Anything I need to know?  I think there was something about having to use the GW lower stem bearing and the CB upper, but maybe that was just for Timken bearings.
I just got off the phone with a guy who has a GW front end. He says it got wrecked in the rear, so he bought stuff to make a trike using the GW front. He didn't do it because the wife got in the way.
It appears to be complete.
http://fortwayne.craigslist.org/mcy/1234413063.html
BTW, does anyone have part numbers for tapered roller bearings?  My CB bearings are notchy, and I don't know if I can use the GW's bearings in the CB neck.
Offline fishhead
  • Why don't you go.....Well, you know the rest.....
Re: gold wing swap
« Reply #1 on: June 26, 2009, 01:39:00 PM »
That's a 75-77 GL front end (6 bolt brake discs- 78-79 have 5 bolt brake discs and Comstars).
 Heres 2 links with info.
http://forums.sohc4.net/index.php?topic=46084.msg484557#msg484557
 And
http://forums.sohc4.net/index.php?topic=46362.msg486489#msg486489
Quote from:  Vanna White
Photobucket slide show (Fishhead Big Brakes)
http://s111.photobucket.com/albums/n130/dgfischer/Fishhead%20Big%20BRakes/?albumview=slideshow
