Did you print those gauge faces up yourself? They look really great! Care to pass on the Technique?
Yes. I printed them myself using HP Photo paper..
Disassemble gages. You must cut the small chrome band that holds it all together. Once this is done you can completly
disassemble both units. The needles can be removed by very gently prying them off. Now remove the two screws that
hold on the face plates.
Take both old faceplates and scan them. Now that you have electronic image. You will manipulate the image to get what
you want. First I convert the image to two color. Back and white, then I remove everything from the image that I don't need.
I remove everything accept the division marks. Now rotate the image such that the first division mark "ZERO" is at the bottom.
Now come back and add numbers and text. Print final product on HP photopaper and carefully cut them out..
Spray paint needles. Install new gauge faceplates, Install needes at 180 degrees " straight down" Reassemble unit and install on bike.
Points to consider... I do not expect HP photo paper to hold up in direct sunlight. Matters little to me.
1. I can replace them in 20 minutes
2. This is not my number 1 rider. This is just my fiddle toy.
Also. I had to manufacture the round faceplates that support the paper faceplates. I used .090 Lexan.
This is the short description. If you are interested in the speedo and tach images I've created, give me email address and I will send them. You may or may not be able to use them.They could be a starting point for your own application. There seem to be small differences in speedo/ tachs between models.
