Author Topic: Quick electiracal question  (Read 740 times)
Offline noisebomb
« on: July 07, 2009, 01:22:55 PM »
Just curious, when you are dealing with a bulb socket, which of the two wires is the positive, and which is the negative.  One wire comes from the center of the socket, and the other is attached to the outer wall.  see poorly made diagram to see what I am asking.
Thank you all...
Johnny
1978 cb750K
Offline tlbranth
Re: Quick electiracal question
« Reply #1 on: July 07, 2009, 01:39:14 PM »
pretty sure the centre is + and the outside is - (ground)
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline mystic_1
  • 1970 CB750K
« Reply #2 on: July 07, 2009, 02:13:28 PM »
That's the common convention, but really light bulbs themselves don't care which is positive and which is negative.  Some lights, however, ground the socket directly to a chassis ground rather than a harness ground, so in that case it matters.
mystic_1
- John Augustus Shedd
Offline noisebomb
Re: Quick electrical question
« Reply #3 on: July 07, 2009, 02:22:43 PM »
Okay then, specifically, the bulbs inside the speedo and tach.  Brown wire comes from the center, green wire is soldered to base.  I just want to know because I am trying to maintain factory colors on the wires, so it will be easier to troubleshoot compared to factory wiring diagram.
1978 cb750K
Offline mystic_1
  • 1970 CB750K
« Reply #4 on: July 07, 2009, 02:33:15 PM »
Green is the standard color for ground in these harnesses, brown is positive.
mystic_1
Offline noisebomb
« Reply #5 on: July 07, 2009, 02:36:29 PM »
Thank you so very much, sir.  Should have these things put back together tomorrow.  Will post pics.
1978 cb750K
