Author Topic: Changing oil filter  (Read 1160 times)
rsmith550
Changing oil filter
« on: November 16, 2005, 12:16:10 PM »
This bike has been apart for some time now - I have forgotten which order the oil filter housing, bolt, and spring are supposed to be in. is the spring against the housing/filter or engine/filter?
Offline Bob Wessner
  • "Carbs Suck!"
Re: Changing oil filter
« Reply #1 on: November 16, 2005, 12:22:28 PM »
Starting from the bolt head end, it's small "o" ring, filter housing, large "o" ring, spring, thin flat washer, then filter.
rsmith550
« Reply #2 on: November 16, 2005, 12:25:09 PM »
Thanx!
Offline dusterdude
« Reply #3 on: November 16, 2005, 01:04:37 PM »
whoo hoo,way to go bob,another non k8 guy saves the day
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
rbswang
« Reply #4 on: April 16, 2006, 09:49:59 PM »
Anybody know the size of the small o-ring? My drain plug had a similar size o-ring...is it supposed to? Would like to use the same size if posibble for that replacement since it worked fine up until now. Thanks!
