Author Topic: CB350F engine gasket kits?  (Read 1724 times)
anchored
« on: July 14, 2009, 07:41:33 AM »
Hello,
I'm in need of a complete engine gasket kit for a rebuild on my '73 CB350F and was wondering if anyone could recommend where to locate a genuine honda complete kit.  If not available does anyone know if Athena's quality is any good? They seem readily available from the oldbikebarn.  Any thoughts appreciated.
thanks
-d
bioman
Re: CB350F engine gasket kits?
« Reply #1 on: July 14, 2009, 07:43:58 AM »
Hi There
Have you tried David Silver spares UK, they stock the largest range of genuine
Honda 350, 400 spares.
Regards
Offline hoodellyhoo
  • CB350F
« Reply #2 on: July 14, 2009, 03:47:10 PM »
DO NOT order from oldbikebarn:
http://forums.sohc4.net/index.php?topic=7235.0
Genuine Honda gaskets seem to be the best. Complete sets show up on ebay once in a while, might even be one on therenow.
Offline fmctm1sw
« Reply #3 on: July 14, 2009, 03:57:38 PM »
Someone just posted about finding a set somewhere..  One of the "regular" 350F crowd...  mattcb350F?
"Cycle Recycle" the name of the place?  Whoever bought it said there was none listed in stock but they had them...
« Last Edit: July 14, 2009, 04:03:15 PM by fmctm1sw »
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
anchored
« Reply #4 on: July 15, 2009, 07:53:01 AM »
Thanks for the tip on cycle-recycle @ www.crc2onlinecatalog.com & www.davidsilverspares.co.uk.
I've been given the option to replace my gaskets and get into a possible rebuild, although the bike runs well but leaks, or consider swapping out to a 400F engine.  I like the idea of a bit more power and understand that the 400F is an overall better engine.
Any thoughts?
Thanks
-d
Offline fmctm1sw
« Reply #5 on: July 15, 2009, 06:11:53 PM »
I've heard of guys bolting them right in but a member here made a comment about the bottom end being wider and the pegs (or was it the gearshifter) being a potential problem.  There is also a post here that discusses a 350F top end on a 400F bottom end.  I'm thinking about it too.  I have lots of 350F engine parts and a locked up 400F motor...
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
