Author Topic: 750F thread?  (Read 182173 times)
Offline Tugboat
  • Puppet
    • PseudoMoto
Re: 750F thread?
« Reply #675 on: June 21, 2011, 11:19:01 AM »
Hang something heavy from the brake pedal overnight. This will allow air to escape the system much easier.  I use speed bleeders and had the same issue; always do with rear brakes for some reason. The weighted brake lever always fixes it.
With the bleeder nipple open or closed?
Offline Silverback
Re: 750F thread?
« Reply #676 on: June 21, 2011, 12:39:52 PM »
Since you have speed bleeders you would just leave it shut. Speed bleeder won't purge unless you add more volume to the system (i.e. pushing the lever over and over). Once the lever is held down, more fluid won't be pulled into the system. Normal bleeder you would want to crack open a bit. I've used this method wit both styles of bleeders.
« Last Edit: June 21, 2011, 12:44:35 PM by Silverback »
Chris
"It's hard to define soul. You get it in art. You get it in music, and occasionally you get it in machinery."
78 CB750F racer
78 CB750F stock
75 CB750K Baby Blue Sold (She was a great bike!)
71 CB750K (rusty rod)
77 cb550F Sold :(  Bought it Back :)
Basket case 73 CB750, 77 CB750F (Building now)
01 Aprilia Falco
76 kz400
96 BMW K1100LT
Offline CafeDawg
  • Not All Those Who Wander Are Lost!
  • Gone to the Dogs
Re: 750F thread?
« Reply #677 on: June 21, 2011, 02:25:47 PM »
Damn how did I miss this thread!!!  Been here on sohc4 a few weeks and had the bike ('78CB750F) a few more weeks than that.  I really like my F3, like the triple disc,the comstars, the rear cowl, has good power and handles good enough for me. Done a few mods and the PO took good care of the bike.  Psyched I found a niche within the forum just for F's.
Respect!
CD
http://
Respect & Understanding. U get what U give!
1976 CB550 basket case cafe rebuild
http://forums.sohc4.net/index.php?topic=106235.0
1978 CB750F evolving, daily rider
http://forums.sohc4.net/index.php?topic=89745.0
Offline jahmic
    • 78 750F
Re: 750F thread?
« Reply #678 on: June 22, 2011, 01:56:49 PM »
While pulling apart my carbs I noticed that 2 of the mixture screws are missing the washer from the "screw-spring-washer-oring" assembly.  I'm thinking about going to the hardware store and looking for a replacement...but am not sure I'll be able to find something that small.
Looking at the parts fiche, I'm having a heck of a time identifying which washer I need to order.  Anybody mind pointing me in the right direction?  I checked out the o-rings, and they still look good aside from a couple divots where the springs were seated on top of them, but nothing that wouldn't iron out once the washers are set on top...so I'd rather not order a full rebuild kit or assembly.  I've seen them on ebay for $14 each...not bad, but money saved is money earned...no...money that can go into other parts for the bike, haha.
If anybody has a source for those washers, it'd be much appreciated.
Offline Tanqueracer
  • "You can't step into Victory Lane with your foot on the Brake"
  • www.yanquetanque.com
    • Yanque Tanque racing
Re: 750F thread?
« Reply #679 on: June 22, 2011, 05:40:32 PM »
Just thought I'd post some pics of my '75 CB750F Super Sport. Bought it in January with only 9000 miles on it from a collector in Fla. Rebuilt the carbs/brakes/front forks, soaked and lubed the chain, changed the oil and away I went. Have put 1,300 miles on it since March. It runs perfectly and rides just the way I remember it did from the 70's (Had a new yellow one for 1.5 years) ;D.
I also added the second front disc last week, cause I think the 2 disc look is cool 8).
Thanks to Rangelov for the speedo drive ;)
« Last Edit: June 22, 2011, 05:42:26 PM by Tanqueracer »
"The older I get the faster I was"!
Offline brandEn
Re: 750F thread?
« Reply #680 on: June 22, 2011, 05:41:41 PM »
Go to Radio Shack and in those bins they keep all the parts in look for a small bag of assorted washers. You will find exactly what you need!
Offline jahmic
    • 78 750F
Re: 750F thread?
« Reply #681 on: June 22, 2011, 06:58:59 PM »
This is why I love this forum  ;D ;D
Thanks for the simple solution, I was wondering where I'd find washers that small.  Radio Shack didn't cross my mind even for a second...I've definitely seen those there before and will be picking them up shortly.
Cheers
Offline Freaky1
Re: 750F thread?
« Reply #682 on: June 24, 2011, 05:10:25 AM »
Thanks brandEn, I had the carb kits already then pulled them apart to find two of these missing from my carbs also & they are not in the kit.
That which does not kill you leaves cool scabs which turn into awesome scars.
'77 CB750F Come on...were almost there!
Offline brandEn
Re: 750F thread?
« Reply #683 on: June 24, 2011, 05:51:03 AM »
Glad I could help. Those washers also work well to shim your needles up if they are not notched.
Offline jahmic
    • 78 750F
Re: 750F thread?
« Reply #684 on: June 24, 2011, 07:41:40 AM »
Apparently someone in Denver has been going around and stealing washers out of 750F carbs.   >:(  :P
Offline jahmic
    • 78 750F
Re: 750F thread?
« Reply #685 on: June 25, 2011, 04:44:53 PM »
I was foolish and decided to not label tubes the first time pulling  these carbs...
Where does the tube on the left connect to? I have all  of the breather element and overflow tubes accounted for, and realize the tube on  the right goes to my petcock...
But I'm stumped after staring at my bike for an hour...what am I missing?
Offline Trav-i
  • Has finally become an
Re: 750F thread?
« Reply #686 on: June 25, 2011, 05:15:48 PM »
It's the vent line.  It was usually run down by the swing arm, that plastic piece is where the extension goes on.  My extension hose is currently missing, but has no effect on how it runs.
Travis
Forum member #9962
1992 GL1500 Interstate
Offline Freaky1
Re: 750F thread?
« Reply #687 on: June 25, 2011, 05:31:55 PM »
My needles are not notched but I have the earlier model set I was running and thought about swiping those. I'd rather not though.
Offline jahmic
    • 78 750F
Re: 750F thread?
« Reply #688 on: June 25, 2011, 09:46:52 PM »
Travis
Haha, thanks so much. I knew I didn't remember disconnecting that...
Offline brandEn
Re: 750F thread?
« Reply #689 on: September 01, 2011, 09:19:00 PM »
New Pics
Re: 750F thread?
« Reply #690 on: September 01, 2011, 09:28:14 PM »
Very nice mate.... ;)
Offline b82ta
Re: 750F thread?
« Reply #691 on: September 01, 2011, 09:36:43 PM »
New Pics
Des Moines eh?
Ever make it up to Ames?
Edit: didnt read the 'washington' below, thought it was another Iowan. my bad...  8)
Btw your bike is Siiiiick looking, really dig that paint scheme.
Mine is much less 'shiny' but still an F ;)
Here it is with the 2up seat on, still havent adapted my Cafe seat for the new frame mods this time around.... maybe this weekend I can get it done.
« Last Edit: September 01, 2011, 09:38:27 PM by b82ta »
Offline kap384@telus.net
Re: 750F thread?
« Reply #692 on: September 02, 2011, 08:56:46 AM »
New Pics
Way to pull this thread from the depths!  Sweet pics deserve quoting!
1965 Honda CB450K0
1972 Honda CT70K1
1975 Honda CB400F Supersport
1977 Honda CB750F2 Supersport
1978 Honda XL100
1979 Honda CBX Supersport
1982 Honda VF750S Sabre - Adventure Bike modified
1983 Honda CX650T
1995 Honda VFR750
2016 Honda CRF1000L Africa Twin
2015 KTM 200 XC-W
1963 Suzuki T10
My 1977 CB750F restoration - http://forums.sohc4.net/index.php?topic=66779.0
My 1975 CB400F restoration -
http://forums.sohc4.net/index.php?topic=145196.msg1651779#msg1651779
'More Stock Than Not' thread - http://forums.sohc4.net/index.php?topic=90807.500
My CT70 Resurrection - http://forums.sohc4.net/index.php?topic=145221.0
Best Motorcycle Tool Ever - https://www.engduro.com
Offline Tugboat
  • Puppet
    • PseudoMoto
Re: 750F thread?
« Reply #693 on: September 02, 2011, 09:07:12 AM »
Any of you F0-F1 guys ever mount PD carbs & an airbox? Did you have to make any mods?
Re: 750F thread?
« Reply #694 on: September 02, 2011, 04:52:45 PM »
I've installed them on a K2 mate, they fit straight on using K7/8 carb rubbers, and work real well indeed, I'd recommend them. This won't worry you, but there's a problem with fitment with the "K" series sidecovers on the F2/3 airbox, the airbox is slightly wider than the K's, and I cracked my sidecover when I re-installed it over the F2 airbox I used. Cheers, Terry. ;D
Offline dgilbertson9
Re: 750F thread?
« Reply #695 on: October 18, 2011, 08:13:42 PM »
I need new carb boot rubbers for my 78 750F and I cant find them anywhere. I was wondering if boots from a 76 would "work".
Offline Tugboat
  • Puppet
    • PseudoMoto
Re: 750F thread?
« Reply #696 on: October 19, 2011, 10:46:44 AM »
'76 had the old style carbs, so no.. you'll need '77-78.
Offline RSchaefer
Re: 750F thread?
« Reply #697 on: October 19, 2011, 11:06:36 AM »
Hey along those lines.  I have a '75F and purchased a '78F tank and compatible petcock.  I understand there might be an issue with the '78 petcock fitting around my '75 carbs, is that correct?  Is it possible to make it work?
Thanks!!
'66 CB77, 305 Superhawk (Project Bike)
'72 CL 175, (Project Bike)
'75 CB750F (Project Bike, Complete)
'05 GL1800 ABS Black Cherry (Current Ride)
'87 GL1200 Wineberry Aspencade
'83 GL1100 Wineberry Aspencade
'76 GL1000 LTD
'75 GL1000 Turquoise
'69 Honda 750cc Gold
'67 Honda 305 Dream Black
'63 Honda S90 Black
'61 Honda 50 Red
GWRRA #000008
VJMC Member
Offline ofreen
Re: 750F thread?
« Reply #698 on: October 19, 2011, 12:31:02 PM »
Thanks!!
You will have to route the fuel line a little differently, but it works.
Greg
'75 CB750F
Offline RSchaefer
Re: 750F thread?
« Reply #699 on: October 19, 2011, 12:41:09 PM »
Thanks Greg, I heard differing opinions, one of which "It can't be done!"  Your picture was great, just what I needed!
Best regards, Rich
'76 GL1000 LTD
'63 Honda S90 Black
'61 Honda 50 Red
GWRRA #000008
VJMC Member
