Author Topic: cb350f - sitting for 20 years- Pics  (Read 1980 times)
Offline Prospect
« on: July 19, 2009, 12:39:45 PM »
Hello
I picked up a 74 cb350f that had been sitting around for 20 years.  I paid $450. The bike is 100% complete (the headlight I took out for my cb400f) I was going to partially restore the bike over the winter to ride it next summer.  It's pretty rusty and I'm concerned about the state of the engine.  When I kick it over there is much less resistance than expected.  I did a compression test on #1 and #4 (kickstarter) and I'm getting 15 psi and 45 psi.  In fact it's even hard to register anything on the gague unless I kick it for a while (10 kicks) Is it common for these bikes to loose compression after sitting for so long due to internal rust? I'm not sure if it's worth it to restore if I have to tear down the engine.
Current Bikes
1969 CB750  Sandcast #256
1971 CB750K1
1972 CB750K1
1975 CB400F
1975 GL1000 Goldwing
1954 Harley Davidson Panhead
1957 Harley Davidson Panhead
Toronto Canada
Offline Bodain
  • I love the smell of fresh asphalt in the morning!
Re: cb350f - sitting for 20 years- Pics
« Reply #1 on: July 19, 2009, 01:24:54 PM »
It's not likely it lost compression merely by sitting for years. It is likely it was parked many years ago because it stopped running from lack of compression. Most likely a valve problem.
2009 Suzuki TU250
2014 Honda Grom
1988 Yamaha FZ600
2018 Honda Ruckus
1971 Honda CB500
Offline Hush
« Reply #2 on: July 19, 2009, 03:20:27 PM »
Could be the rings are stuck in their grooves, this will cause blow by and will totally screw your attempts to get a compression test reading.
At $450 I'd take it and restore, looks like it has a good set of CB400f pipes on it too.
Unstick those rings before you condemn that engine mate. :)
Offline JB_Pgh
« Reply #3 on: July 20, 2009, 01:18:21 PM »
Junk it, but sell me the seat first.  ;)
Nice find for the money!
72 CB350F project
« Reply #4 on: July 20, 2009, 02:17:52 PM »
I'll take it!
Are you out here in the West?
Dang, what a find!
Offline strangedaze39
  • 1972 CB350F
« Reply #5 on: July 20, 2009, 07:14:29 PM »
I'd say thats a fair deal. You probably got the upside if anything, because now you have a CB350F! ;) I'd rebuild the engine if the pistons are fine and the casing doesn't have any cracks. If you need some valves let me know I have a extra set laying around. First thing you need to do is start tearing that engine apart, and clean those carbs. I will bet all the money in fort knox it's not going to run without a carb rebuild  :D
If you need any help with that thing, don't hesitate to ask. I'm still learning everyday.
Good luck with the bike!
1972 Honda CB350F
Offline petercb750
« Reply #6 on: July 21, 2009, 02:20:57 AM »
Do the world a favour and restore it! It's too complete to junk.
1972 750/4 K2 (his), 1976 400/4 (hers)
1982 CB1100RC (ours)
Offline bucky katt
  • i am a pastafarian!
    • facebook
« Reply #7 on: July 21, 2009, 02:27:44 AM »
dump some pb blaster or another penetrating oil into the spark plug holes...ALOT then let it sit for a few days to posen possibly stuck rings. do another compression test then, might just be stuck rings. were the plugs oily when you pulled them?
Mark Twain - Notebook, 1894
Offline Prospect
« Reply #8 on: July 21, 2009, 05:14:42 AM »
Thanks for the ideas.  I'll probably make this a 2-3 year project to space out the costs.  I'll try the ideas you guys suggested and if still no compression then I'll put in a cb400f engine, ride it and keep working on the cb350f engine.
I knew it was a good price when I saw it and that's why it sold 90 minutes after listing.  Like I mentioned there is a lot of surface rust and fading.  It was stored under a loose tarp in a shed.  The tank is rusty but I think I'll be able to salvage it with por15.  It'll require a total tear down, carb work (already ordered kits from a board member) paint, new spokes, spark wires, caps, etc.  We'll see about the exhaust ($$$). It's very similar to the cb400f which I've worked on for the last year.  I've learned from it and hopefully I won't make the same mistakes on this one!
Gotta go.  Taking my cb400f for it's maiden (long distance) voyage.
Current Bikes
1971 CB750K1
1972 CB750K1
1975 CB400F
Toronto Canada
