Author Topic: Valve spring compressor  (Read 2322 times)
Offline joeb
« on: November 19, 2005, 05:57:06 PM »
I need a valve spring compressor for my 750 .  Long story short I ordered one from jc Whitney and it does not work. Going to send it back. Thanks all. >:(  Oops forgot where can I get one. Thanks
« Last Edit: November 19, 2005, 06:00:16 PM by joeb »
Re: Valve spring compressor
« Reply #1 on: November 19, 2005, 06:05:20 PM »
Why dose it not work?
Offline joeb
« Reply #2 on: November 19, 2005, 06:12:39 PM »
Well  its to big cannot compress the springs.
« Reply #3 on: November 19, 2005, 06:22:48 PM »
Joeb,
Can you not put a packing between the valve head and the screw ?
Offline joeb
« Reply #4 on: November 19, 2005, 06:31:24 PM »
Yep thats what I did got the spring off but when I went to put the new one in stuff went every where . Could be just fatigue but I gave up for today in frustration.  Could not get the spring to center so I could put in the keeper.
« Reply #5 on: November 19, 2005, 06:37:56 PM »
Don't worry to much,  that can happen at times, even when you have the correct valve clamp   ;D
Offline joeb
« Reply #6 on: November 19, 2005, 06:43:16 PM »
Well I quit for the day sounds like its Miller time . Would still like to get a better fitting valve compressor.
« Reply #7 on: November 19, 2005, 06:58:27 PM »
You can get addjustable ones, but the beer does sound better ;D
« Reply #8 on: November 19, 2005, 07:32:12 PM »
I use a Kowa Seiki compressor...it has different adaptors to screw in to compensate for different size retainers. It has never failed me. Me good friend Dana(for Sam) has a Pingel compressor that works with compressed air (he also has a stanh alone tool that works with air just for R&R of retainers). Boyh are the berries. It took him almost 1 year to get his Pingel(years ago) and when I checked about getting one Pingel said forget it. The Kowa tool is great BUT if you don't use it alot it's not worth the price(unless you like to own great tools)!
Offline Bodain
  • I love the smell of fresh asphalt in the morning!
« Reply #9 on: November 19, 2005, 08:18:06 PM »
You don't really need no stinking valve spring compressor. You need a hammer, a proper socket and skill.
I've used this method before reading this article, but it explains it well.
http://www.dansmc.com/valve.htm
2009 Suzuki TU250
2014 Honda Grom
1988 Yamaha FZ600
2018 Honda Ruckus
1971 Honda CB500
Offline scondon
  • Mmmm......tasty bugs
« Reply #10 on: November 19, 2005, 11:57:23 PM »
Is this the compressor you got?
http://www.jcwhitney.com/autoparts/Product/tf-Browse/s-10101/Pr-p_Product.CATENTRY_ID:2004242/showCustom-0/p-2004242/N-111+10201+600003570/c-10101
And if so did they send ya the right one? There are two listed but only one should work for your bike.  Item #ZX510065A
The reason I ask is that I bought one from them a few years back and it works great. It was not the exact same one though. JC Whitney changed to the "one handed" design but otherwise they look the same. Just wanted to know if the new design is a turd so I don't make any bad recommendations.
Offline Raul CB750K1
« Reply #11 on: November 20, 2005, 05:55:55 AM »
A recently bought a cheap one in a hardware store. It comes with two jaws, one straight and one angled, so you can adjust it to shorter valves. The handles moves like in those jaw grips, so you can quicly adjust the distance and then, with the lever, slowly compress the spring. No problems with it. Send a link of the one you bought.
Raul
Offline joeb
« Reply #12 on: November 20, 2005, 08:34:52 AM »
Sean this is what I recieved,catalog #  510065 valve spring compressor heres  a  picture of it . I have been going back and forth with them it looks nothing like the one they advertised.  Hope this helps .
« Last Edit: November 26, 2005, 01:09:42 PM by Glenn Stauffer »
« Reply #13 on: November 20, 2005, 01:42:33 PM »
I've done that many times BUT it doesn't help getting the retainer and keepers back on. ;)
Offline scondon
« Reply #14 on: November 20, 2005, 01:55:18 PM »
joeb, The one you have looks near identical to the one I got a few years ago with the exception that your ratcheted arm is waaaaaaayy shorter. I can see now why doing your valves has been such a pain.
     They had two versions of your type of compressor and one was advertised to "work on motorcycle engines". Possible that you received the "car only" version. If the JC Whitney experience hasn't left too bad a taste then maybe just send yours in exchange for the proper one.
« Reply #15 on: November 21, 2005, 12:03:44 AM »
Yep, it looks a little too long.
This is how I removed the valves on my CB350Twin head. Check that there is a spare set of jaws -for shorter reach- attacked with duct tape to the compressor. I didn't even need them.
I have to agree that, for 30 euro, it's not worth the pain to remove the springs or, even worst, to put them back.
Raul
Offline joeb
« Reply #16 on: November 21, 2005, 12:36:36 AM »
Well just got back from delivering 50,000 lbs of lumber to Home depot in Fresno wi;; call jc whitney in teh morning and see what they say.  :-\
Offline Lumbee
    • My pics...
« Reply #17 on: November 21, 2005, 11:02:00 AM »
"I'm not a welder, but I play one on HondaChopper.com"
