Author Topic: Any Ideas  (Read 2726 times)
Offline Sparked
  • Cheaper then therapy
Any Ideas
« on: July 22, 2009, 04:55:58 PM »
Found this in my oilpan of my CB350F,  250 miles after rebuild.  I'll post more info when I have time tomorrow, hopefully with more pictures as well.  it is a part of aluminum casting about 2" diameter
1972 CB350F
1982 CM450A
1961 Ford Falcon (time for four wheels)
Re: Any Ideas
« Reply #1 on: July 22, 2009, 04:59:25 PM »
 :o :o :o :o :o :o :o  ???
Offline bucky katt
  • i am a pastafarian!
    • facebook
Re: Any Ideas
« Reply #2 on: July 22, 2009, 05:14:02 PM »
you sure thats not a chunk of compression ring?
Mark Twain - Notebook, 1894
Offline mystic_1
  • 1970 CB750K
Re: Any Ideas
« Reply #3 on: July 22, 2009, 05:26:22 PM »
The right side of the photo sure does look like it has a square cross section, but the left side looks different... smooshed?
mystic_1
- John Augustus Shedd
Re: Any Ideas
« Reply #4 on: July 22, 2009, 05:30:11 PM »
Aluminum compression ring ;D ;D ;D ;D ;D have you been on the hard stuff fuzzy :D :D :D :D :D
Sam. ;) ::)
technojock
Re: Any Ideas
« Reply #5 on: July 23, 2009, 01:46:53 AM »
FWIW, It looks like part of the head gasket but it's hard to tell for certain.  It's possible that it dropped into the case when cleaning up the remains of the old gasket.
Tony
Offline greenjeans
  • 1972 CB750K2
Re: Any Ideas
« Reply #6 on: July 23, 2009, 06:19:05 AM »
Maybe part of the ring that holds the screen together ?
Offline turninwheels
Re: Any Ideas
« Reply #7 on: July 23, 2009, 06:29:38 AM »
huh....that can't be good :o
"high powered suicide machine."
Offline Sparked
Re: Any Ideas
« Reply #8 on: July 23, 2009, 04:55:50 PM »
Ok, here are some better pictures of the part that I found.  It is cast aluminum.  I'm almost thinking of the edge of the snap ring groove on the bearings for the primary shaft?  Also with the amount of aluminum shavings in the oil pan and filter how much of a cleanup job am I looking at.  I've got my fingers crossed for not having to do another full tear down, but if I have too... there's got to be improvements I could make the 2nd time around.
1972 CB350F
1982 CM450A
technojock
Re: Any Ideas
« Reply #9 on: July 23, 2009, 05:15:05 PM »
After seeing the better pix and hearing about the shavings, I don't see how you can get away without tearing into it.
Tony
Offline Sparked
Re: Any Ideas
« Reply #10 on: July 23, 2009, 05:45:01 PM »
Yeah, Soon as I saw what was in the oil pan I came tothe same conclusion.  I'm really curious what happened and why too.
1972 CB350F
1982 CM450A
Offline honda750k
Re: Any Ideas
« Reply #11 on: July 23, 2009, 05:56:41 PM »
I have no idea what that came from, but you've got SOMETHING not right, judging by the aluminum shrapnel all over that oilpan, and surrounding everything else.
These bikes dont die, they hibernate until the right person wakes them up again.
Offline mystic_1
  • 1970 CB750K
Re: Any Ideas
« Reply #12 on: July 23, 2009, 07:22:07 PM »
Congrats on having some of the more mysterious sump pan debris I have seen.
One would think that whatever forces broke off that piece, would have distorted it more.
Keep us posted on what you find.
mystic_1
Offline Sparked
Re: Any Ideas
« Reply #13 on: July 23, 2009, 09:25:35 PM »
Well, soon as I get some free time I'm going to pull the engine and open it up to see what happened.  It was running oh so nice up until.....ouch
1972 CB350F
1982 CM450A
Offline Sparked
Re: Any Ideas
« Reply #14 on: January 25, 2010, 06:29:52 PM »
So I got the engine all apart and between 2 I am building one.  I don't have the space to rebuild it myself at the moment so I'm having a local old bike mechanic do the assembly for me.  The shrapnel came off the inside of the case by the inner primary shaft bearing.  The bearing is fine, so we are kinda stumped as to why the snap ring would have sheared off the retaining flange.  It's such a clean break from the case that I'm wondering about just a failure in the casting.   So looks that by the time the snow is off the ground, I'll have a freash built bike ready for the season early this year.
1972 CB350F
1982 CM450A
Offline Sparked
Re: Any Ideas
« Reply #15 on: September 18, 2011, 09:51:33 PM »
The engine wasn't worth rebuilding, but after 2 years of patiently waiting I have found a low(ish) mile barnfind bike with a solid engine in it.  The project is back underway!!!
1972 CB350F
1982 CM450A
