Author Topic: Stock CB750 4 in 4 installation question  (Read 2214 times)
Offline mycb750k6
  • "res ipsa loquitur"
  • Rocketman
    • photobucket albums
« on: August 01, 2009, 06:10:40 AM »
I have a 71 CB750 that I removed the kerker from and am about to install stock pipes. After some amount of effort I located a set of exhaust flanges and bolts. I did a test fit and am wondering about the thickness of the copper exhaust gaskets. Do these rings compress a great deal when tightened down? Seems like they must flatten out in order for the fit of the flanges to be correct and having done that they probably can't be used again? I didn't see any copper gaskets in there when I pulled the kerker. Did it require them and I'm just not seeing them? Finally, how to torque down the flange bolts? I've read many stories about how these are impossible to remove once installed. Should I use anti-seize on the threads, grease? When tightened down should the flanges be flush with the mating head?
Offline 333
  • Time for change
Re: Stock CB750 4 in 4 installation question
« Reply #1 on: August 01, 2009, 06:15:22 AM »
Yes, they compress.  They are the gasket.  Sometimes the old ones are hard to see, and have to be dug out.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline Gordon
  • 750K1, 550K2
« Reply #2 on: August 01, 2009, 06:26:26 AM »
It's almost a guarantee that there are old gaskets already in there.  This subject comes up almost weekly where somebody swears there are no gaskets in the exhaust ports, we tell them to look closer and gently pry around in there, and sure enough they were in there.  The get squished completely flat and covered with carbon so they blend in with the rim of the port.
On one of my previous bikes there were actually two sets of old gaskets in the exhaust ports because the PO didn't realize the first set was already there and put another set on top.
« Last Edit: August 01, 2009, 06:28:14 AM by Gordon »
Offline mycb750k6
  • Rocketman
« Reply #3 on: August 01, 2009, 06:30:30 AM »
OK so the Kerker definitely used the same copper gasket? Otherwise it probably would have been leaking? For all I know there could be a dozen in there.
Offline Gordon
  • 750K1, 550K2
« Reply #4 on: August 01, 2009, 06:36:35 AM »
Correct.
Online Johnie
« Reply #5 on: August 01, 2009, 06:48:23 AM »
Yes, the old ones are covered with carbon and that is why you can not see them.  The pic below will give you an idea of where they are.  Click the pic...
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline mycb750k6
  • Rocketman
« Reply #6 on: August 01, 2009, 10:31:44 AM »
Well they were right there where you said they'd be but it did take some digging to get them out.
Second part of question is how much force to use when putting exhaust spigots back in?
Online Johnie
« Reply #7 on: August 01, 2009, 10:36:53 AM »
Just put the gaskets in place and then screw down the exhaust flanges.  Tighten the screws a little at a time on each so the flange goes back in straight.  I tighten them as tight as I can with a large screwdriver.
Oshkosh, WI  USA
Offline mycb750k6
  • Rocketman
« Reply #8 on: August 01, 2009, 03:51:14 PM »
Got it, hurray almost done.
Offline petercb750
« Reply #9 on: August 01, 2009, 04:39:38 PM »
When I put the new exhaust on mine, I found I had to check the flange screws and collar bolts now and then and nip them up, but all has settled down.
BTW, sweeeeeet looking bike mate. Don't new pipes make a difference!
1972 750/4 K2 (his), 1976 400/4 (hers)
1982 CB1100RC (ours)
Online Johnie
« Reply #10 on: August 01, 2009, 07:08:10 PM »
Agree...nice looker there!!!
Oshkosh, WI  USA
Offline Zaipai
    • My Home page
« Reply #11 on: August 01, 2009, 07:30:57 PM »
Nice looking ride to be sure. Its good that its almost done..
Its my Avatar..
75 CB550F  |
Offline bucky katt
  • i am a pastafarian!
    • facebook
« Reply #12 on: August 01, 2009, 08:03:58 PM »
i use a pick tool to get the old gaskets out
just be careful you dont gouge the aluminium
Mark Twain - Notebook, 1894
