Author Topic: Anyone in the Chicago area??  (Read 1561 times)
ateamsam
« on: August 08, 2009, 03:53:02 PM »
Hey guys,
I'm having trouble trying to perform my first tune-up and was wondering if anyone on this board was in the Chicago area and would mind helping me out.  I live in the northwest burbs, a town called Bartlett (by St. Charles and Elgin).
Offline johnyvilla
Re: Anyone in the Chicago area??
« Reply #1 on: August 09, 2009, 01:49:56 PM »
What do you need help with? What bike?
ateamsam
« Reply #2 on: August 09, 2009, 02:58:53 PM »
good point jonnyvilla.
i've got a 1974 cb550 that i'm working on.
Offline johnyvilla
« Reply #3 on: August 09, 2009, 08:04:30 PM »
What kind of tuneup do you need help with? Valves, points, timing, sync, cam chain tension?
Is your bike stock- what have you changed?
If you wouldn't mind riding out to Aurora this week I might be able to help you.
ateamsam
« Reply #4 on: August 10, 2009, 06:00:33 AM »
Hey Jonnyvilla,
My bike is completely stock and I'm just trying to do the cam chain tension and the valve adjustment until I buy a carb sync tool.  I've got the tank off and I fiddled with the valve adjustment but am not sure I am doing it right.  I'd hate to put it back together and ride it over in case I've done something wrong.  Would a half an hour ride do much damage if the valves are slightly off?  If not I can always hassle a buddy to let me borrow his truck.
Offline mystic_1
  • 1970 CB750K
« Reply #5 on: August 10, 2009, 08:11:29 AM »
Even a single rotation of the crankshaft can bugger things up of there's something really out of whack with the valves.
Describe your fiddling to us.  Unless you changed the tappet settings a lot you're probably OK.  How far have you turned them from their starting points?
Bartlett is kinda far for me, hopefully someone closer can pop in, the whole tune-up procedure only takes an hour or two barring problems or parts availability issues.
mystic_1
- John Augustus Shedd
