Author Topic: emulsion tubes  (Read 1220 times)
Offline jimbir
emulsion tubes
« on: August 14, 2009, 07:57:26 PM »
'76 CB550F
Is there a preferred orientation when reinstalling the needle jet emulsion tubes?
Thanx, Jim B
1976 Honda CB550F
Offline Hush
Re: emulsion tubes
« Reply #1 on: August 14, 2009, 08:20:01 PM »
I don't believe so, I just screw mine in until firmly in place, don't care which direction the holes face. :)
Offline Zaipai
    • My Home page
Re: emulsion tubes
« Reply #2 on: August 14, 2009, 08:23:47 PM »
On my 75 CB550F I also just screwed them and did not pay attention to the direction, and she runs like a top. However I am by no means an expert nor do I have mass experience working on any bike.
Its my Avatar..
75 CB550F  |
KingCustomCycles.com
Re: emulsion tubes
« Reply #3 on: August 15, 2009, 05:03:14 AM »
I have done hundreds of carbs and if there is an orientation I have gotten very lucky.  I believe the air holes (emulsion holes?) are randomly placed.
Offline Hush
Re: emulsion tubes
« Reply #4 on: August 15, 2009, 05:05:36 AM »
Hey Jimbir, they do on my 650 ha ha. ;D
Offline mystic_1
  • 1970 CB750K
Re: emulsion tubes
« Reply #5 on: August 15, 2009, 06:03:53 AM »
I just thought they might face in a particular direction.
No worries, they don't :)
You CAN however mess with the sizes and numbers of holes in order to change the way your carb runs.  There's some info in the Carb FAQ.
mystic_1
- John Augustus Shedd
Re: emulsion tubes
« Reply #6 on: August 15, 2009, 06:33:03 AM »
The carbs are buttoned up but not installed on the bike. Then I have one of my anti eureka moments and this thought comes up. The holes are not random. There's a straight line of holes drilled thru and a single cross drill at 90 deg to them at the midpoint of the tube. I just thought they might face in a particular direction.
Thanx
Random in relationship to the jet which screws in at the bottom, and further randomness when the assembly is screwed into the carb body.  What would you do to orient them anyway?  Shim the body?  Honda will mark most critical assembly operations with a dot or a letter or something.  They also commonly use keyways and alignment dowels.  Don't over think these carbs.  If they are clean and bench synched, they are good to go.
