Author Topic: Today's dummy.... Me! Now with points pictures..  (Read 2132 times)
Offline fmctm1sw
« on: August 22, 2009, 01:23:47 PM »
My '73 was not running very well.  I had a spare set of carbs that I totally dismantled and took great care putting back together (or so I thought).  I got the carbs on it and took it to the gas station to put gas in it.  It ran fantastic until it got hot; which is what it was doing before.  It misses under acceleration.  I got home and checked the timing.  It was spot on.  I needed to sync the carbs too with my Morgan.  I couldn't for the life of me get this thing sync'd.  Idle was all over the place.  It would rev up and stay revved up, sometimes at 4000 RPM!  I had to snap the throttle or twist it backwards for it to come down.  I tweaked and tweaked for what must have been almost 2 hours off and on.  I decided to pop off the top of a carb (slide cover?) to see if any were sticking.  Damn, I left the throttle slide bolts and the 7 mm bolt that holds the arm assembly loose ???  I planned on messing around with the needle positions and forgot all about it.  Once I got that ironed out everything worked great as far as the sync went.  My plugs were carboned up so I cleaned them up but also noticed my points are pitted.  Tiny little craters are in them.  Perhaps an ignition tune up will supply better spark for me and help with the plugs.  Anyway...  the dumb move of the day...
« Last Edit: August 22, 2009, 05:28:24 PM by fmctm1sw »
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline Bill/BentON Racing
    • BentON Racing
Re: Today's dummy.... Me!
« Reply #1 on: August 22, 2009, 02:13:22 PM »
Not so bad at least it ended well,once had tech forget to put the main jets in on a pipe and jet job!Bill
BentON Racing Website
BentON Racing Facebook
Offline bucky katt
  • i am a pastafarian!
    • facebook
« Reply #2 on: August 22, 2009, 03:35:00 PM »
way better than MY dumb move  :D at least you didnt have to replace cam and cam towers and rockers like me  ::)
Mark Twain - Notebook, 1894
Offline fastbroshi
  • Puppet
« Reply #3 on: August 22, 2009, 04:33:25 PM »
Are the points' craters so deep that a nail file wouldn't take them out?  Otherwise just replace them.
Just call me Timmaaaaay!!!
Offline fmctm1sw
« Reply #4 on: August 22, 2009, 05:29:21 PM »
Here's how they look after a less than 5 mile ride.
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline OldSchool_IsCool
  • Really feeling like an
Re: Today's dummy.... Me! Now with points pictures..
« Reply #5 on: August 22, 2009, 06:05:30 PM »
Holy Shot Condensers, Batman!
Are those points new or freshly cleaned?  Do you know the history on the condensers?
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline fmctm1sw
« Reply #6 on: August 22, 2009, 06:17:51 PM »
5 miles after cleaning.  I even squeezed my brass brush from my rotary tool in there.  They were real nice except for the tiny pits.  I bought the engine from a guy a couple summers ago.  No clue on history...
*edit*  I did put more than 3000 miles on that engine though.  I thought the carbs were at fault so I cleaned up a spare rack I had the same thing happened.  The thought about taking the ignition parts off my very well running '72 crossed my mind but it gets harder and harder to mess with a  properly running bike.  I have some old parts coils, points, and condensors laying around too.  I may fool around with them...
« Last Edit: August 22, 2009, 06:21:52 PM by fmctm1sw »
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
    • BentON Racing
« Reply #7 on: August 22, 2009, 07:52:29 PM »
We didn't put new pts in w/out new condensers on any in line 4s from that era,usually it was always new pts,new condensers as it should be with all pt/condenser ignitions.Bill
Offline fmctm1sw
« Reply #8 on: August 22, 2009, 08:13:30 PM »
I just ebayed new points/condensors.  We'll see what happens.  I also have a junk set of coils I'm going to rewire as discussed in the FAQ...
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
« Reply #9 on: August 22, 2009, 09:50:07 PM »
New points come with a greasy coating of cosmolene to protect them. Although it will eventually burn off, it is FAR better to clean is off first, with acetone or something similar. Then this initial pitting is far, far less. This goo is a pretty good insulator, so much so that if someone installs new points with one of my Ignitions, and does not clean them, it has trouble trying to read the points for the spark.
Old condensors will also EAT new points. Mmmmm...  :P
« Reply #10 on: August 23, 2009, 06:01:11 AM »
Oh, and a Hondaman Ignition Module would be a definite plus!  It's not a requirement by any means as good 'ol points and condensers have worked GREAT for centuries!  (I think the Romans timed the spark on their chariots with them, could be wrong tho).
I have one and couldn't be happier with it.  Add one to your Christmas list if nothing else.
Read about 'em here:
http://forums.sohc4.net/index.php?topic=15948.0
Sure.
Is it hard?
    • BentON Racing
« Reply #11 on: August 23, 2009, 06:04:53 AM »
A,lways clean contact surfaces anytime you're there,sometimes cosmolene so heavy,no connection and like Hondaman said any left will cause problems.Bill
