Author Topic: balanceing the carbs  (Read 2973 times)
qcextreme
« on: April 20, 2005, 05:55:24 AM »
I have a 74 CB350 Four will I need to balance the carbs, and if so what’s is balancing and how do you do it
sradja
Re: balanceing the carbs
« Reply #1 on: April 20, 2005, 06:12:29 AM »
You could buy a carb syncronizer and sync them. JC Whittney sells them at there web site.
Offline Harry
    • CB500F
« Reply #2 on: April 20, 2005, 06:13:06 AM »
Look in the FAQ and find the downloadable SOHC manual which will take you through step-by-step.
Harry Teicher, member #3,  Denmark....no, NOT the capital of Sweden.
eldar
« Reply #3 on: April 20, 2005, 02:08:33 PM »
You will need a syncronizer but you may as well get it from the honda shop. I got mine for $45. yes jcwhitney has it for $40 but once you factor in shipping then the honda shop was cheaper and I could inspect it before buying it!
Online SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
« Reply #4 on: April 21, 2005, 01:53:37 AM »
I would recommend a Morgan Carbtune, they're easy to use but more than $40...
Mine were £20 on eBay (UK)
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
Ibsen
« Reply #5 on: April 21, 2005, 02:04:12 AM »
This is the pricelist from Morgan:
http://www.carbtune.com/carbpric.html
And yes, it is expensive, but it is a great tool :)
qcextreme
« Reply #6 on: April 23, 2005, 05:42:31 AM »
what screw/bolt do i Use to balance the carbs...
Offline Dennis
« Reply #7 on: April 23, 2005, 09:07:05 AM »
it's a little more complicated than what screw but to answer your question directly the adjustment is done on the carb linkage.
your really going to have to download the carb section and read the book.
be sure to do a "complete tune-up" including ignition and valve adjustment before balancing
