Author Topic: ...changed jets, now won't start...  (Read 1393 times)
Offline Lumbee
    • My pics...
« on: December 01, 2005, 03:41:41 PM »
78 750K
...sup all, changed from 110 to 120 jets and now it won't start...rolls over a little, but nothing else.  Am I missing something?  Running pods and pipes...started fine with 110s...
"I'm not a welder, but I play one on HondaChopper.com"
Buffo
Re: ...changed jets, now won't start...
« Reply #1 on: December 01, 2005, 04:29:51 PM »
what do you mean by "rolls over"
Offline scondon
  • Mmmm......tasty bugs
« Reply #2 on: December 01, 2005, 04:59:01 PM »
Petcock "on" and fuel in bowls?  Run switch off????
Seriously, can't think of any reason a jet change would stop your bike from starting.
Offline Lumbee
    • My pics...
« Reply #3 on: December 01, 2005, 06:55:26 PM »
...yes to all of the above...when I said "rolls over" I just meant it pops like it wants to start, but won't.  Got spark...I'll sleep on it...maybe something will come to me.  Just thought maybe I needed to do something else if I changed jets...
Buffo
« Reply #4 on: December 01, 2005, 08:18:09 PM »
did you bugger the float hights when you did the jets?
I dont remember if the mains have o-rings in them or not (between the main and the stem)...if they do, did you install them?
And I take it you tried the drain screw on EACH carb to make sure they all had fuel.
Offline Lumbee
    • My pics...
« Reply #5 on: December 01, 2005, 08:22:26 PM »
...turned the drain screws, and got fuel.  The carbs are probably dirty.  This is a set of carbs I brought back from the dead, so I'm sure there is lurking garbage in them.  I've got a set of carbs I know is good...I'll put those on this weekend and see what happens.  Oh the woo's of carb troubles!!!! ::)
