Author Topic: 750 gasket set  (Read 522 times)
Offline johnyvilla
750 gasket set
« on: September 09, 2009, 04:22:52 AM »
I have a Cometic head gasket for my 836 project, but need to source the rest before I can move on with this build. Since head gaskets are the most expensive part in a gasket set, would it make sense to buy the remaining gaskets individually from Honda; or would I spend the same amount just buying a complete aftermarket set? Has anyone been in this situation?
Thanks
Offline scondon
  • Mmmm......tasty bugs
Re: 750 gasket set
« Reply #1 on: September 09, 2009, 11:12:23 AM »
I buy the complete(top/bottom) Vesrah sets and set the stock head gasket aside. Buying gaskets/o-rings/seals separately can be a bit expensive. If I have to go back in the engine for some reason, I'll buy individual gaskets since some will still be good for re-use.
Offline johnyvilla
Re: 750 gasket set
« Reply #2 on: September 09, 2009, 11:43:49 AM »
That makes sense Scondon.
