Well, I'm proud of myself. I thought I was losing my touch, but it turns out only half the engine is sparking - so the hassles carb tuning and setting the points have just this morning become clear.
I knew the right side tailpipe wasn't blowing as hard as the left, and had thought it was plug wire #3, which I just trimmed, even though #4 sent a strong strobe signal to the timing light, and #3 did a bit and #2 did it seemed, I assumed it was the wire covers on #2 and #3 blocking the strobe signal, whereas on #4, it was just the 7 or 8 mm core exposed.
So I get out there 10 mins ago and clip #3 wire like the help here suggested ( Thank you members ) - yeah it's a copper wirestrand core all right - put the cap back on and start her up - ran just like my 10 mile trip last night - ON TWO CYLINDERS I find out!
LOL
Yeah, NO HEAT on the right pipes - ZERO - and she's sitting there running....
Guess I'll have to change the oil as soon as I correct that little problem...
No wonder I couldn't get "the points set correctly" or so it seemed.
Yes, I wimped out and bought a DS-2 electronic ignition and installed it.
Yes, I was whacking away on the floatbowl idle screws for a week.
Yes, I hope the electronic ignition and/ or 2,3 coil isn't fried.
Last night before the ride I pulled #3 wire while it was running, no change in speed but the main fuse blew seconds later.
I replaced it and took my 5 mile trip to the client's party I was invited to.
Got stopped for no taillight and a warning ticket issued, the cops were very curious about the bike and we were talking for 10 mins - the taillight is on/off depending on the "short" in the "switch" key area - if the key is just so it's on.
When I pulled into the lot and she died, the taillight remained on. Ahh haaaaa -" See officer, it's ON, maybe you're seeing things ? "
Ok, so anyway, I'm very hopeful now that it will run GREAT like it did two years ago - I guess I've been tuning with only 2 cylinders going most of the time.
Yes, I was bragging there at the beginning, you were probably laughing - ha, oh crap I'm scared to go out there and rev her up and see if she's really stoking on just 2 cylinders and that has been my problem... it just can't be.. can it ?
