Author Topic: 750 vs. 550 forks??  (Read 1359 times)
Offline chippyfive50
  • NO PEE ON TEPEE
    • thesweetimpala
750 vs. 550 forks??
« on: December 07, 2005, 01:23:16 PM »
Is the only difference between a cb 500/550 fork and a 750 fork the length of the 35mm down tubes / spring strength??
(I want to  put the shorter 500 tubes in the 750 bottoms.)  anyone anyone??
SOHC Member#4000
71' 500K0 #1021237--E1108327
78' 550
72' 750K2(sold to "Craig")
74' 750K4 #2306334--E2303422
73' CL175
http://gallery.sohc4.net/main.php?g2_itemId=14013
Re: 750 vs. 550 forks??
« Reply #1 on: December 08, 2005, 08:01:34 AM »
If you do you will have to use the 500 braking system, disc, caliper, caliper bracket
Offline dusterdude
« Reply #2 on: December 08, 2005, 08:41:38 AM »
bryan,he wants to put 550 tubes in the 750 legs,that shouldnt affect the brake setup should it?
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline n9viw
  • Floyd, '76 CB550k
« Reply #3 on: December 08, 2005, 11:12:30 AM »
So long as he uses the 550 internal pistons with the 550 tubes, his plan will work flawlessly. The 750 uppers are 1.5" longer than those of the 550, and the 750 lowers are 0.5" longer than those of the 550, so he will see a total redux of 1.5". (I received this information from the gal at Forking by Frank, the late Frank's wife IIRC)
And yes, the relative brakes must follow their lowers. On my 550, I plan to mount a pair of 750 forks and a 750 front wheel to take advantage of the increased leverage of the slightly larger 750 brake disk. It's this disk (in addition to mounting-hole spacing) that constitutes the difference between the 550 and 750.
« Last Edit: December 08, 2005, 11:14:10 AM by n9viw »
Nick
'76 Honda CB550k
'73 Honda CB750k
  • NO PEE ON TEPEE
    • thesweetimpala
« Reply #4 on: December 11, 2005, 08:16:39 PM »
Hey n9viw,
     Thanks for the help, you are on the money all the way around on my intentions. I want to use the 750 wheel / disks as well, but you are saying the bolt patterns are different from a 550 to a 750??
so now  I need a 750 wheel/hub  as well?
SOHC Member#4000
78' 550
73' CL175
