Author Topic: where does this wire go?  (Read 1142 times)
Offline cike
« on: September 26, 2009, 08:40:26 AM »
I took my battery box out, sandblasted it and painted it. When I put it back together I have a green wire that I don't know where it goes. I took a pic before taking it apart, but I can't see this wire in it.
 I do still have the green wire that runs to the brake light.
 Anyone know where this might go? It runs into the same group of wires as the starter magnetic switch (solenoid?)
 My bike is a 1973 CB750
Thanks
Offline moham
  • .fnord.
Re: where does this wire go?
« Reply #1 on: September 26, 2009, 08:42:32 AM »
That might be an extra ground, somebody else will know for sure...
78 750K-The Ocho
74 550-The Cherry Picker
70 750K0 motor-Dick in a Box
Offline Skonnie Boy
    • What I do for a "living":
« Reply #2 on: September 26, 2009, 08:43:27 AM »
I could be wrong, but I think that wire goes to the turn signal buzzer.  Hardly anybody has them on their bikes anymore.  I've actually never seen one.  Feel free to correct, I don't have my wiring diagram handy.
Yee and/or Haw.
Offline mystic_1
  • 1970 CB750K
« Reply #3 on: September 26, 2009, 08:47:16 AM »
That is the extra ground wire used only on 3 leg blinker relays.  Older hondas used two leg blinker relays.
mystic_1
- John Augustus Shedd
Offline cike
« Reply #4 on: September 26, 2009, 08:57:57 AM »
THANKS!!
Skonnie Boy is the turn signal buzzer the small box on the back of batery box marked "signal stat"? if so, mine still has it. May have to get rid of it if my signals start buzzing. (at least i'll know how to make it stop now)
thanks moham, Mystic
Offline mystic_1
  • 1970 CB750K
« Reply #5 on: September 26, 2009, 09:10:53 AM »
Turn signal buzzer is inside the headlight bucket and looks like a small can with a perforated side.
The item on the back of the battery box is the turn signal relay.
Check the main website, wiring diagrams are available for your bike there.
mystic_1
Offline Skonnie Boy
« Reply #6 on: September 26, 2009, 10:35:12 AM »
There you have, I stand corrected.  Mystic's prolly forgotten more than I'll know about these bikes.
Yee and/or Haw.
Offline cb350twin
    • http://mail.google.com/a/sohc4.net/
« Reply #7 on: September 27, 2009, 12:49:37 AM »
My turn signal buzzer is not inside the headlight bucket.( 75 K5) But  jammed up next the fork ears and next to the headlight, with a rubber hosing, with the holed metal plate for sound
1975 CB 750 K5
1972 CB 350 Twin K4
1972 CB 500 Four K1
Offline Johnny5
    • CB350F build thread
« Reply #8 on: September 27, 2009, 04:16:16 AM »
I've never seen the buzzer in the headlight bucket (among the mass of wires, didnt know it'd even fit), but rather I always find them perched on top of the fork cap.
www.kerosenecycles.com
1971 CB350
1973 CB350F
2006 Harley Springer Classic
Offline mystic_1
  • 1970 CB750K
« Reply #9 on: September 27, 2009, 06:04:49 AM »
Ah yes that's right, the stock mounting point is a little tab that sticks out on the inside of the fork ear.  I've only encountered one "in the wild" and it had been stuffed up inside the headlight.  Still have that one floating around in my parts collection but don't even know if it works.
mystic_1
