Author Topic: IDIOT ?  (Read 2405 times)
NE550
IDIOT ?
« on: September 27, 2009, 09:07:27 AM »
I took my front wheel, fender, brake caliper and forks off.  I cleaned everything up and put a new tire on.  I didn't take any pictures while I did this and and stumpped.  I got the forks back on and when I attempt to put the wheel on the forks are about 1/4 inch to narrow, it wont line up with the axle.  I have taken the axel out to check if the little tabs for the speedometer are liined up, which they were, tighten it and it still wont line up.  Also I don't remember the order to put them back.
Any help would be appreciated ???
Matt
NE550
Re: IDIOT ?
« Reply #1 on: September 27, 2009, 09:21:09 AM »
Do the fork oil drain plugs belong in the front or back?  Mine are in the back
Offline Johnie
Re: IDIOT ?
« Reply #2 on: September 27, 2009, 09:40:20 AM »
Back is correct...
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Re: IDIOT ?
« Reply #3 on: September 27, 2009, 09:51:25 AM »
You got your axle and or spacer in backwards..
Offline MickeyX
Re: IDIOT ?
« Reply #4 on: September 27, 2009, 09:54:56 AM »
I'm trying to get what you are doing here since you still didn't take any pictures, apparently.  :D  So, you say the forks are now 1/4 closer to each other than before? Are you sure you put the correct fork on each side? Yes, the oil plug should be to the back. The fender holes should be to the inside.
Did you put the axle in from the right (if you were sitting on bike, it is the right) and then the nut on the left? We actually had a mechanic try to put it in backwards and tell us it was correct. It didn't fit at all and was sticking out kinda weird and wouldn't tighten up right. We ended up walking into his shop, grabbed his bike jack and did it ourselves right in front of him. Jackass.  ::)
Go look on bikebandit's parts fiche to see if you are missing something. http://www.bikebandit.com/honda-motorcycle-parts/oem-parts
good luck. :)
Offline crazypj
  • I'm brill, me
Re: IDIOT ?
« Reply #5 on: September 27, 2009, 10:31:13 AM »
Sounds like fork tubes may be bent?
 They will fit either side, just means calipers are behind instead of in front of forks (and drain bolts end up in 'high' spot)
PJ
« Last Edit: September 27, 2009, 10:37:36 AM by crazypj »
Offline Ogri
  • Thinks he's a
Re: IDIOT ?
« Reply #6 on: September 27, 2009, 10:43:17 AM »
Did you put the cylindrical nut, (that sits on the axle, holding the axle in the wheel)  back on the right way round ?
Re: IDIOT ?
« Reply #7 on: September 27, 2009, 11:08:29 AM »
Quick test for bent forks:
 loosen one side so you can turn it, but not so it drops.
 Then tape a pen/stick/ruler (only one) to the other fork in the axle hole so it just about touches the other fork, then slowly turn the loose fork & observe the gap at the pointer. If it changes its bent.
 Then you either strip, and fix/replace, or move the forks so that the bends are forwatd, then use it..
Offline SohRon
Re: IDIOT ?
« Reply #8 on: September 27, 2009, 12:25:14 PM »
Here are some pics that may be of help:
« Last Edit: September 27, 2009, 02:19:14 PM by SohRon »
Offline Johnie
Re: IDIOT ?
« Reply #9 on: September 27, 2009, 12:40:55 PM »
More pics...click to enlarge.
Oshkosh, WI  USA
NE550
Re: IDIOT ?
« Reply #10 on: September 27, 2009, 12:44:32 PM »
John, that's how mine looks hence my confussion, I'll try to post some pics
matt
NE550
Re: IDIOT ?
« Reply #11 on: September 27, 2009, 01:53:31 PM »
This is how the axle is positioned.
This shows how the forks do not line up properly
Offline 750goes
  • it will live
Re: IDIOT ?
« Reply #12 on: September 27, 2009, 02:19:49 PM »
You are missing the axle spacer that sits inside the axle nut...
Offline Johnie
Re: IDIOT ?
« Reply #13 on: September 27, 2009, 02:33:48 PM »
Looks to me the spacer is on there and in the correct position. The spacer is located next to the of the nut in his upper and lower pic. What happens if you loosen the upper fork tubes in the tree and spin them? Will you create a wider gap? If so then the tubes may be bent...give it a look.
« Last Edit: September 27, 2009, 02:36:58 PM by Johnie »
Oshkosh, WI  USA
Offline 750goes
  • it will live
Re: IDIOT ?
« Reply #14 on: September 27, 2009, 02:42:25 PM »
I'll put my glasses back on -thanks
If the left fork is not moveable - and there is no "play", then the fork tube could be bent, or the top triple clamp and steering is out of whack somewhere..
I would loosen it all up - then tighten it up in position - then tighten from the bottom up
- axle clamps
- axle
- lower clamps
- upper clamps
You could also loosen the left fork and rotate it relative to the lower leg..
Re: IDIOT ?
« Reply #15 on: September 27, 2009, 03:47:32 PM »
Again, turn axle around, put the nut, on the speedo side..
NE550
Re: IDIOT ?
« Reply #16 on: September 27, 2009, 05:20:52 PM »
Johny,answered the $1,000,000 question correctly.  i just spun the forks in the upper tree and for some reason it worked.  My only problem now is the extra wide tire, 110/90.  It is rubbing against the fender mount that holds the brake line.  Gonna try to make a gap, or return the tire.
Re: IDIOT ?
« Reply #17 on: September 27, 2009, 05:28:00 PM »
if you spun it, and the gap changed.. You have a BENT Fork, or two..
 No Maybe, it IS bent.... deal with that before saying the tire does not fit..
Offline crazypj
  • I'm brill, me
Re: IDIOT ?
« Reply #18 on: September 27, 2009, 06:05:20 PM »
chalk another one up to me  ;D
PJ
Offline cb550fcafe
    • KDI Cycles
Re: IDIOT ?
« Reply #19 on: September 27, 2009, 06:24:54 PM »
My 110 front tire rubbed also. Although I don't have any bent forks. I just had to bend/manipulate the fender bracket around to get clearance, its tight! Most guys that run a 110 tire I've meet don't run a front fender.
