Author Topic: 74 CB350F Cam Chain Tensioner  (Read 885 times)
needonemore
« on: September 29, 2009, 06:41:14 PM »
Rookie wrench question: I saw the FAQ section for how to get the cam chain to adjust.  It mentions a cap bolt that needs to be removed to gently push the mechanism with a Phillips screwdriver. I have a bolt about 1-1/2" above the adjuster bolt and locknut assembly, sort of behind the frame/engine attachment point.  Is this the cap? Any help is much appreciated.
Mark
Offline fmctm1sw
Re: 74 CB350F Cam Chain Tensioner
« Reply #1 on: September 29, 2009, 06:53:52 PM »
From what you describe I think that's it.  Prepare for 3rd degree burns if you do it while it's running...
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
needonemore
« Reply #2 on: September 30, 2009, 03:39:13 AM »
No kidding! Have you had this problem! Thanks for the reply.
Mark
