Author Topic: bike eats oil.???????  (Read 2156 times)
Offline Beans
  • I play with grease every day.
  • 1975 cb550f
    • bean's place.
« on: September 29, 2009, 12:44:20 AM »
OK did a long search and couldn't come up with anything on here or the web.   but my bike eats oil. Ive noticed this the past few months since it blows some smoke out of the exhaust and well I have to add oil every other week or so.   can anyone tell me why this is happening?  Im going to adjust the valves because they tick but I don't think that would cause it.  can someone help me out.  am I do for an engine rebuild or is it something simpler then that?   I want to get this fixed soon so I don't have to keep adding oil so much.
Keep it shinny side up.
Offline jeepster
Re: bike eats oil.???????
« Reply #1 on: September 29, 2009, 01:45:17 AM »
Worn rings? Hows the compression?
"An ounce of prevention is worth more if you break it up into nickel bags."
Offline Hush
« Reply #2 on: September 29, 2009, 02:03:26 AM »
I've had my bike back on the road for nearly a year now and it only just occured to me today to check the oil, it was just showing on the dip stick. :P
Basic check I know but you have so many other things going on with these bikes, I probably wouldn't have checked it even then but I was readjusting the clutch and was in the vacinity.
Lets see, bike uses oil, could be worn rings, could be worn valve guides, could be a leak.
Any oil spots where you park your bike?
Any drips after a ride?
You could be losing it from a leak as you ride and not notice it.
Offline Beans
  • 1975 cb550f
    • bean's place.
« Reply #3 on: September 29, 2009, 08:20:20 AM »
I just thought it was weird since I just changed the oil begining of las week.  Ill check compression and everything soon.  Their is a little leak at the shift shaft so maybe that's it but the leaks not that bad.
Offline Gordon
  • 750K1, 550K2
« Reply #4 on: September 29, 2009, 08:38:41 AM »
I think if it were leaking that badly you wouldn't be able to miss the puddle underneath your bike or your oil-soaked jeans after a ride.  Definitely do a compression check.
Offline Beans
  • 1975 cb550f
    • bean's place.
« Reply #5 on: September 29, 2009, 08:56:14 AM »
Yea I'm going to do a compression check friday when I adjust the valves.
Offline lrutt
« Reply #6 on: September 29, 2009, 09:29:18 AM »
a compression check will not prove or disprove a ring problem. The oil control rings do not play much of a role in maintaining compression.
Smoke on starteup is guides, smoke while running is rings, smoke on decel is guides.
Offline jeepster
« Reply #7 on: September 29, 2009, 01:08:17 PM »
Plugs might also be oil fouled.
Offline Inkscars
  • grumpiness comparable to an
« Reply #8 on: September 29, 2009, 01:16:33 PM »
Your oil bag get nice and hot?
This seems familiar.  ;D
81 Hardly Davisson
Offline Hush
« Reply #9 on: September 29, 2009, 03:06:29 PM »
When you fill up after an oil change you need to wait for the oil filter to fill up before adding more, otherwise you get a false reading.
A slow fill with a few stops works best then leave it on main stand while you have a coffee then recheck.
Offline Beans
  • 1975 cb550f
    • bean's place.
« Reply #10 on: September 29, 2009, 07:11:32 PM »
I'm thinking maybe that was my problem. I didn't give the oil filter time to fillu up idk I added more oil and am going to run the bike and check it again in a few days.
