Author Topic: pressing in the keihin main jets with new o-rings  (Read 1451 times)
Offline restforyoursouls
« on: October 01, 2009, 07:28:45 PM »
I ordered new o-rings for my keihin 110 main jets on my '75 550.  The o-rings are 3.5mm x 1.5mm Buna.
I was tapping the new jets in with the smallest hammer imaginable and everytime I tap the jet in fully, it cuts some of the excess rubber off the o-ring that wouldn't fit into the carb body.....make sense?
Anyways, I was wondering if this is normal and if the jet will seal proplerly?
The jets seem tight in the carb body.
I did some searching on here and from what I found, I ordered the correct o-ring size.  They are from Mcmaster-Carr.
.a slow bike that runs great is a lot less frustrating than a fast one that doesn't.
'72 CB450 twin...leavin' it stock
'75 CB550 four....shoulda left it stock :)
'71 CT70
'75 CT70
Offline 1timduke
  • '75 CB550
Re: pressing in the keihin main jets with new o-rings
« Reply #1 on: October 01, 2009, 07:33:31 PM »
A little spit will help it slide in w/o losing any skin off the surface.   Jokes aside, this is my proven technique for tight rubbers... assuming they are indeed the right size. ;)
-Tim
The only thing I miss about the South is Waffle House!
« Reply #2 on: October 01, 2009, 07:50:12 PM »
i used a little shot of carb cleaner.....just as good as spit, right.  still cut em.
'71 CT70
'75 CT70
Offline mystic_1
  • 1970 CB750K
« Reply #3 on: October 01, 2009, 07:51:28 PM »
+1 on the spit.
Also, don't tap them in.  Instead, push firmly while rocking the jet, I like to use a slight circular motion to ease the jet in.
mystic_1
- John Augustus Shedd
« Reply #4 on: October 01, 2009, 08:04:46 PM »
i'll try the circular motion and see how it goes.....thanks mystic
'71 CT70
'75 CT70
Offline mystic_1
  • 1970 CB750K
« Reply #5 on: October 01, 2009, 08:09:52 PM »
You can use oil to lube things up too, when you run gas through the carbs it'll wash the oil off.
mystic_1
