Author Topic: Float Bowl drain plug orings  (Read 1067 times)
Offline TomL
« on: October 05, 2009, 12:42:42 PM »
Anyone know where I can find o-rings, or replacement drain plugs for my carbs?  The ol' 350 is dripping a little on occasion and I have a feeling the old rubber is done for.
Re: Float Bowl drain plug orings
« Reply #1 on: October 07, 2009, 09:44:17 AM »
If its same as 500 try 16175-001-004
Offline 1974CB750rider
  • 1974 CB750K4 46000 miles
« Reply #2 on: October 07, 2009, 09:49:11 AM »
Go to the local autoparts store and pick up an o-ring assortment pack for less than $3.00. The one you need will be in it. Honda will not order just the o-ring you have to buy the whole carb kit. At least my local honda dealer said that. I just had the same problem.
People with closed minds cannot learn new things.
Offline Blueridgerunner
  • CB650 no longer, but do have an 87 GL1200
« Reply #3 on: October 07, 2009, 01:02:29 PM »
I found O rings in, of all places, the plumbing department of my local hardware store. There are a lot of different ones for faucets and things.
Said James "In my opinion,  there's nothing in this world, beats a '52 Vincent and a red headed girl"
Laissez les bons temps rouler
Offline TomL
« Reply #4 on: October 07, 2009, 05:40:52 PM »
Hmm.  Maybe I'll check out the hardware store.  I don't care where it came from as long as it stops the leaks.
« Reply #5 on: October 08, 2009, 09:29:53 AM »
That part number is still valid and can be ordered, just dont till the pimply youth what it is for
