Author Topic: CB550 carb needles  (Read 1499 times)
Offline HawaiiMike
    • Hawaii realtor
CB550 carb needles
« on: October 22, 2009, 06:55:33 PM »
I read another thread about poor running in general when carb needles get old and worn.  Then I went to the local Honda dealer and ordered a new set for my '76 CB550F, part # 16012-390-004.  The next day they called me back and said they can't get them from the main supplier.  They're checking with other Honda dealers to see if the needles are still around.
Now I saw a set CB550K needles, part # 16012-323-004.  Sure the taper is probably a little different.  I think it's more important to have four new needles with the exact same shape, even if their taper is slightly different from original.  Heck, I don't even know if the carbs on this bike are original anyways!
The bike is essentially stock, except for a MAC exhaust.
Any thoughts?
Offline Bill Vaughan
1972 Z50A
1973 ST90
1975 CL360
1971 CB450
1975 CB550
1978 FLH
2003 FLSTS
2006 FLHRSI
Offline Otto
Re: CB550 carb needles
« Reply #2 on: October 23, 2009, 06:29:46 AM »
I speak from experience on this one. Carbs off 7 times before realizing that the needle tapers were waaay out of spec from OEM...
Don't use Keyster carb needles or any other non-OEM needles until you absolutely confirm that the tapers are the same as OEM.
If all 4 are the same, but, worng. It's wrong and it WILL drive you crazy.
Call Western Hills Honda or go to David Silvers Spares website and get the OEM needles.
Yep, the cost more, but, will work correclty!
bc
Otto
1971 HONDA CB750K1- Valley Green Metallic
2007 Triumph Bonneville - Silver/Black Carburetted
Offline HawaiiMike
    • Hawaii realtor
« Reply #3 on: October 23, 2009, 11:44:55 AM »
Yeah I read about the Keyster needles and am avoiding those kits.  What about K&L, are those the same parts/is that the same company as Keyster?
Thanks, Mike
« Reply #4 on: October 23, 2009, 09:18:02 PM »
I checked several NOS suppliers before I sent you the link.  None showed your needles as being available.  That's not to say that you won't be able to find them somewhere.
Otto's point is well made - aftermarket carb. sets are not always true to the originals.  I have purchased more than a few sets that contained one incorrect jet size among correct ones.  You should, of course, compare the size markings on the aftermarket pieces against those of the original pieces.
« Last Edit: October 23, 2009, 09:20:04 PM by Bill Vaughan »
1972 Z50A
1973 ST90
1975 CL360
1971 CB450
1975 CB550
1978 FLH
2003 FLSTS
2006 FLHRSI
