Author Topic: 750 cylinders to head mating surface scuff  (Read 2187 times)
Offline bran-don
« on: November 12, 2009, 03:47:00 PM »
   i received some parts in the mail recently, and to my dismay it looks like the seller used a rotary disk to clean up the gasket surfaces and the tops of the pistons! ARG!
 my question is, how bad could it be?  if there are a few scratches or much light sanding, could i just put a gasket on and go? or should i put the whole thing on a surface block and lap out even the smaller imperfections? how sensitive is that surface for compression increases?
  i'd like to hear some feedback about similar situations, and hello to all its my first post!
1974 CB750
1967 Triumph T100c
...please, just one more parts bike
Offline OldSchool_IsCool
  • Really feeling like an
Re: 750 cylinders to head mating surface scuff
« Reply #1 on: November 12, 2009, 03:58:29 PM »
Do you know any speedskaters?  The ones who skate on ice?
I used to be one in a former life.  I still have a diamond sharpening stone used to sharpen speed skates.  It's a long, flat, steel bar coated with diamond dust.  I know the REAL engine builders here will prolly freak when I tell you this, but I use this stone to remove scratches on the mating surfaces of the cylinder block and head.  Any deep scratches get a little HondaBond.  Gouges earn the part a trip to the machine shop.
Welcome to the forum, by the way!
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline bran-don
« Reply #2 on: November 13, 2009, 08:11:26 AM »
so the machine shop would weld the gouge an mill it true?
  sounds like i have a date with hondabond
1974 CB750
1967 Triumph T100c
Offline ColinMc
  • There aint no pickle like a super pickle...
« Reply #3 on: November 13, 2009, 08:22:42 AM »
I would just bring them to a machine shop and have them checked to see how bad they are...they might even just check them quick for free.
1976 CB750K - Cafe Project...taking forever
1984 Honda MB-5 - MB-8 conversion in process
2001 Ducati 748 - Built 996 motor sleeper
Offline Toxic
« Reply #4 on: November 13, 2009, 08:36:31 AM »
+1 on the above.
If that is not an option use a 24" steel ruler on it's edge and lay it across the the cylinders to measure any warping.  I used to know what the standard was. You insert a feeler guage at various points to see if it is within spec.
Nicks and small gouges are not usually a problem on a street motor.
I paid $100 to have my Z1 head and cly machined flat.
