Author Topic: Can I just rebore one cylinder? ( 400/4)  (Read 9403 times)
Offline neilma
Re: Can I just rebore one cylinder? ( 400/4)
« Reply #25 on: November 25, 2009, 12:23:49 PM »
Well thanks for the comments chaps and whilst there isnt a clear consensus on the way forward, I have just ordered a set of 4 oversized pistons and will get the cylinders all bored to suit.
More money  ;D
Cheers
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
« Reply #26 on: November 25, 2009, 12:49:01 PM »
Best decision, in my opinion. :)
No.
Offline Kevin400F
« Reply #27 on: November 26, 2009, 04:44:51 AM »
How big did you go?  Your first post mentioned "deep scores"....are you certain that a .25 (first oversize) will clean it up completely?
Offline neilma
« Reply #28 on: November 26, 2009, 08:13:21 AM »
Oh dear dont get me worried that I havent ordered the right size  :o
Ok back from a quick check in the garage and have now changed my order to the 0.5mm size instead just to be on the safe side. Fingers crossed they can ammend it before processing.
Cheers Kevin.
Offline mystic_1
  • 1970 CB750K
« Reply #29 on: November 26, 2009, 08:40:16 AM »
Best bet is probably to have the cylinders bored before ordering pistons and rings.
mystic_1
- John Augustus Shedd
Offline neilma
« Reply #30 on: November 26, 2009, 09:31:07 AM »
I was told they need the pistons in order to correctly size everything up and bore the cylinders to match the pistons - Is that not true (or am I mistaking it for when I asked around to get them honed instead)?
Offline mystic_1
  • 1970 CB750K
« Reply #31 on: November 26, 2009, 09:38:00 AM »
You know, I'm not sure about that.
I do know that a buddy of mine had his GL1000 bored out and then could not find oversized pistons for it (without having them custom made) so that is an issue.
If the shop doing the work says they need the pistons than I defer to their superior knowledge.
mystic_1
Offline MacM2010
  • Nobody Special
« Reply #32 on: November 26, 2009, 09:43:58 AM »
They probably do need the pistons--the shop did when they re-bored my 750.  If you bring them the jugs, they should be able to tell you how far overbore you'd need to go.  .5 is probably plenty, unless someone really went to town on it with a hacksaw or something.
One day, I will put up a signature.
Offline ttr400
    • ttr400 Projects and Billet parts.
« Reply #33 on: November 26, 2009, 10:22:18 AM »
You must have the pistons first!! before you do a rebore, so they can be measured for the correct piston to bore clearance.
Kevin
CB400F- 492 Yoshi Racer.
Cb400F- 466 Yoshi Cafe.
CR750 D Mann Replica.
VFR750R- RC30 - 1988.
www.ttr400.com
Offline neilma
« Reply #34 on: November 26, 2009, 10:23:51 AM »
Excellent - An end to this saga :)
Thanks all for your wisdom!
Offline mystic_1
  • 1970 CB750K
« Reply #35 on: November 26, 2009, 10:38:53 AM »
Good to know. :)
mystic_1
Online Terry in Australia
« Reply #36 on: November 26, 2009, 05:09:32 PM »
Ha ha, famous last words! ;D
