Author Topic: Wiring CB750F (75-76) Handlebar Controls to CB750K2  (Read 1521 times)
Offline sethdhawkins
« on: November 22, 2009, 12:42:51 AM »
Here's the deal. The old handlebar controls were junk, so I bought these refurbs off ebay. I'm going to attempt to wire them when I return from work on the 1st. I'd like you gents to take a look at my wiring analysis.
CB750F
Left Side Control (L/R Blinker, Horn, H/L Beam Sw.)
Orange/Turn Signals (left)
Lt. Green/Horn
Lt Blue Turn Signals (right)
Lt. blue w/stripe/front turn signal (left)
Brwn w/blue stripe/signal buzzer
dk blue/high beam head lt.
orange w/stripe/front turn signal (right)
white/low beam head lt.
Gray/grd. for signal relay
brwn w/red stripe/instrument illumination
Right Side (Start-Kill Switches)
Blkx2/Positive(eng. stop switch and starter)
Yellow w/red stripe/starter ground
blk w/white stripe/coil side switched
blk w/red/headlight dimmer switched
On the CB750K2 diagram, it appears as if all color line up with one another except for the black w/red trace from the CB750F...where does this go?  Also, the CB750K2 has the H/L/Off switch for the headlight wheras the CB750F just has H/L? How should I approach this?
Thanks for any input,
Seth
Here's eye candy of the new 836cc built by Mr. Rieck!
« Last Edit: November 22, 2009, 12:10:02 PM by sethdhawkins »
All a man needs in this world is someone to love, if you can't give him that, give him hope, if you can't give him hope...just give him something to do!
1972-ish CB750K
1974 CB450
1974 CB360
1976 136' Ocean Going Tug
Offline Head
  • JUST SOME OF THEM- I WAS BUILDING THESE WHEN NEW
    • My Bikes
Re: Wiring CB750F (75-76) Handlebar Controls to CB750K2
« Reply #1 on: November 22, 2009, 01:29:20 PM »
Where there K2 switches on the old bars? I myself replace the switches from K3-F&K8 with the earlier switches, Personal preference, Less wires,
And you have the ability to turn off the headlight, The blue wire and the blue/white strip wire are suppose to go to the same light,same with the orange,orange /white stripe wires. The white striped wires are for the running lights, Are those pic's of your bike?? To me that just sweet! I hope you post more pic's of the build! What are the spec's of the new motor???         Head
1970x2,71,72,74,75K's,75F-FO-750ss, 2 x 75 GL1000, 77 GL1000,  3x 1981 CB900F, 74 550,  1966 CL77 305, 1967 CL77 305, 1974 MX360 Yamerhamer, 1983 CB1100F RED
NOTICE Due to current financial restraints the
Light at the end of the tunnel will be turned off until further notice!! sohc member#1522
Offline Toxic
« Reply #2 on: November 22, 2009, 04:09:31 PM »
Free bump up to the top if you tell me what paint you are using on the alt and tran cover. ;D
Beautiful engine.
« Reply #3 on: November 22, 2009, 10:43:52 PM »
Understood the blue/orange white stripe setup for the running lights. What has me baffled is the black w/red stripe from the headlight dimmer switch, I don't know where this ties in. I wish I could retain the off position with the new controls, but the old K2 controls were beyond junk.  Any help with this black w/red stripe wire would be great! ;D
The engine build sheet from Mike is at home, while I'm stuck in NYC. It reads like a Christmas list though  ;) If anyone is geographically close to this man, it's worth it to reach out, as he's one standup dude.
The case paint is PJ1 Coatings Satin Black Case Paint.
Thanks for the compliments. I've got a build thread going somewhere, maybe I'll update it.  Alot of the stuff I've done has been the boring stuff (bearings, neck bearings, frame paint (don't like how that turned out), and sending various parts to various places). Nevermind, guess I will update the thread  :D
1972-ish CB750K
1974 CB450
1974 CB360
Offline Head
    • My Bikes
« Reply #4 on: November 23, 2009, 05:41:42 PM »
What year of F do you have, I myself just picked up a 1975 750F, the black/red stripe wire from dimmer on mine has a plug in the main wire harness, I don't know if the three years of F have the same wire setup,mine has the box on the other side of the bike from the horn,that the wires join up in.
What are you going to do with the old switches,I am looking for the little copper/brass plate that the starter button makes contact with in the switch housing. This is the first F that I'm working on, But forty years working on Honda's I work mostly on 70--72 750's,cb900f's,cb1100f's and 75--78 Goldwings.   PS  I have two wires, it's brown with a red stripe and a yellow band on it male end, and a brown wire with a blue stripe female end with a cover that is half yellow. My three manuals lump the 75f to 77f for the same wire diagram and it's not the set up I have.
Head
Offline BeSeeingYou
« Reply #5 on: November 23, 2009, 05:59:26 PM »
I believe the black/red stripe wire from the dimmer goes to the headlight fuse and from there it goes to the starter switch.
