Author Topic: 16" rear wheel and sprocket question  (Read 1030 times)
Offline ironbutter
  • 1971 CB750 K1 ~ JDM ~ Polynesian Blue ~ 8K mi
« on: November 23, 2009, 07:10:18 PM »
If my 71 CB750 has had a 16" rim laced to the OEM hub, should I be considering changing my sprockets? Like 14T up front or less than 41 on the rear? Thanks for any replies, I searched and could not find anything. I have NO chain currently, so Im looking to get one, but I dont want to pull the trigger if Im going to have to change my sprockets.
« Last Edit: November 23, 2009, 07:14:58 PM by ironbutter »
"Most motorcycle problems are caused by the nut that connects the handlebars to the saddle."
Re: 16" rear wheel and sprocket question
« Reply #1 on: November 23, 2009, 08:10:22 PM »
Usually the overall diameter of the 16 is not much less than the origianl 18 as the carcass of the tire is so big.
I don't know where such small sprockets as 14/51 could be had. A 14/41 combo is very nearly the same ratio as a 17/48 which was stock on most CB750s (or 18/41, a little taller). The slightly smaller rear wheel will lower the ratio to an effective 16/48 which was a poplar drag racing ratio. Quick get away with tolerable cruising and gas mileage.
I'd suggest the 17/48 for overall performance and chain life. Chains live longer on larger diameter sprockets.
PS I have 3 good used 48T sprockets (no fronts) that have been cryogenecally treated for less friction and longer life. $10 plus shipping (probably $10)
Offline ironbutter
« Reply #2 on: November 23, 2009, 10:19:11 PM »
Thanks MC, well it sounds like the stock setup will be fine, Im thinking my sprockets are in usable condition as the bike only has 8K on the clock. Maybe I should get the 48T from you for a backup. Thanks for the reply.
