Author Topic: Lightened Crank and Replacement Case. Which bearings??  (Read 7194 times)
Offline Ricky_Racer
Re: Lightened Crank and Replacement Case. Which bearings??
« Reply #25 on: November 29, 2009, 10:09:03 AM »
754... Any recommendations or links for proper mics?  Thanks.  RR
« Reply #26 on: November 29, 2009, 10:17:01 AM »
I have been using mostly Mitutoyo, and a Moore & Wright. Starret is good too. Most of them are pricey, but I think there arte lots of used on ebay.
 For offshore stuff, KBC tools  sells well priced stuff that is usually pretty decent quality, they have just a huge catalog of stuff.
 Using the smaller mics, is not as difficult as using the big stuff.. like an 8 inch mic, is a lot harder to get used to..
Offline mystic_1
  • 1970 CB750K
« Reply #27 on: November 29, 2009, 10:18:35 AM »
This type:
mystic_1
- John Augustus Shedd
« Reply #28 on: November 29, 2009, 10:36:42 AM »
754 try 48 inch journals andbores!!!! (Google Doxford)
« Reply #29 on: November 29, 2009, 03:35:19 PM »
Digital micrometers are great for inexperienced users, but expensive. I prefer a digital vernier caliper, they are around for as little as 20 bucks, and the 20 dollar EBay job I use all the time is surprisingly accurate. I just bought a more expensive digital vernier that measures in mm and metric inches, but also in fractions of an inch, which is really cool! Cheers, Terry. ;D
Offline odin836
  • Honda CB750 K3 (...in pieces...)
« Reply #30 on: January 17, 2010, 12:17:41 AM »
Received my Bottom End Studs from Dynoman this week, and was able to give the Plastiguage a go.
I ended up getting all BROWN shells based upon measurements with a digital vernier calliper, and working backwards as suggested earlier in the thread.  Thought it cheaper to use this as a guide and buy one or two extra shells if needed.  Seems pretty good, photos are below, what do you think?
Plastiguage
Plastiguage with paper guide, all squished plastiguage pieces are the same shape/size.
My only problem is this:
A broken Dynoman bottom end stud, snapped off at about 15 ft lbs, all other studs stood fast at the recommended 20 ft lbs.  (My heart sank when I heard the crack!)
I have emailed Dynoman, hopefully they are happy to send a single replacement stud.
CB750 K3 in pieces.
Offline mick7504
« Reply #31 on: January 17, 2010, 01:32:22 AM »
This broken stud business is no good.
Yours is another in recent times that has been reported.
From memory, the last ones were cylinder studs and now a case stud.
It certainy puts a question mark over the quality control procedures.
If I was you
I'd be worried about me.
« Reply #32 on: January 17, 2010, 08:12:12 AM »
I had a case stud snap off exactly as Odin described
Offline odin836
« Reply #33 on: January 18, 2010, 06:23:05 PM »
Mike, glad its not just me...
With the number of mean machines you've built its got to be poor materials.
I have received an email from Dynoman (this morning).
They are sending a replacement stud today, downside is it typically takes 2 weeks stuff to Aus from the US.
« Last Edit: January 19, 2010, 03:59:22 AM by odin836 »
CB750 K3 in pieces.
« Reply #34 on: January 18, 2010, 08:35:36 PM »
They are sending a replacement stud today, downside it it typically takes 2 weeks stuff to Aus from the US.
....but Buzz is very good about that stuff. Still.....it's uncomfortable
Offline JLeather
« Reply #35 on: January 18, 2010, 08:46:21 PM »
huh.  I have a set of case studs from that same batch.  Hope they'll be alright.
Offline odin836
« Reply #36 on: February 03, 2010, 12:57:30 AM »
Dynoman sent me a single replacement stud pretty quick.
Plan on trying to get things together this weekend.
Hope the replacment performs better!
CB750 K3 in pieces.
« Reply #37 on: June 12, 2011, 12:33:47 AM »
Well I checked my F1 cases and crank today, and was surprised that the crank wasn't stamped, but rather, the code was lightly scratched (yep scratched, not even engraved) into the position described above. Interestingly the case letters and the crank letters are all the same, AAAAA. Looks like all yellow shells are the go. Cheers, Terry. ;D
« Reply #38 on: June 12, 2011, 10:50:43 PM »
Terry crank was never stamped they used one of those electric etch pens mate
« Reply #39 on: June 13, 2011, 12:57:26 AM »
Fair enough Bryan, I can't remember the last time I looked, when I rebuilt my blue K2 I just used all green bearing shells and it was fine, I suppose anything is better than 40 year old ones, ha ha! ;D
