Author Topic: Removing the gas latch pin  (Read 965 times)
Offline kevins750
« on: December 13, 2009, 12:25:02 AM »
Can I safely remove and reuse that pin holding the thumb latch on a 750 tank? If so how?
2003 YAMAHA ROADSTAR
1975 CB750F(build date 1/75 #313)
1978 CB750K
1973 CB750K(w/velorex sidecar)
Offline City Boy
Re: Removing the gas latch pin
« Reply #1 on: December 13, 2009, 04:34:32 AM »
Hi kevin.You can remove the pin with a small drift punch.As it comes out the flared end will flatten out.You can then reinstall and re-flare the end with a centre punch.    Rock On
'52 Kiekhaefer Mercury Rocket Hurricane KG4H
'70 750/RC 1000 Original Owner
'83 1100F
Offline Alan F.
« Reply #2 on: December 13, 2009, 08:33:30 AM »
If the pin is beyond use afterward (and you're not a purist...) Hondaman has stainless screws and acorn nuts available for a few bucks that'll hold your cap and latch on there.  You'll never accidentally scratch your tank up with tools while tightening these finger tight (with a dot of blue loctite) either.
Offline Gorms
  • Barkeep! Give me a beer and a
« Reply #3 on: December 13, 2009, 09:03:23 AM »
When I bought a cap it did not come with a pin so I just went to the harware store and bough a long bolt (M2.5 maybe?) and a lock nut.  Cut off any excess threads and it looks just fine.
Offline kevins750
« Reply #4 on: December 13, 2009, 09:08:11 AM »
Thanks guys...Just going to get the tank painted and wanted it removed for blasting..
1978 CB750K
Offline Johnie
« Reply #5 on: December 13, 2009, 02:14:41 PM »
Be careful as I have seen people bend that hinge from smacking that pin.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
