Author Topic: Will a '79 cb750 front wheel fit on a '78 cb750 k?  (Read 3800 times)
Offline GAsohc4
« on: December 19, 2009, 03:21:16 PM »
Will a '79 cb750 (k model I believe because its spoked) fit a '78 K model cb750?
if not, any way to make it work?
Any Info much appreciated Thanks!
Offline kevins750
Re: Will a '79 cb750 front wheel fit on a '78 cb750 k?
« Reply #1 on: December 19, 2009, 04:44:22 PM »
use what ever axle goes with the forks you are using...I think the rotor is going to be closer to your fork leg than the SOHC rotor would have been....
2003 YAMAHA ROADSTAR
1975 CB750F(build date 1/75 #313)
1978 CB750K
1973 CB750K(w/velorex sidecar)
Offline bucky katt
  • i am a pastafarian!
    • facebook
« Reply #2 on: December 19, 2009, 06:47:07 PM »
not sure but i think the hub might be too wide. there may be some custom spacers in your future
Mark Twain - Notebook, 1894
Online Don R
« Reply #3 on: December 19, 2009, 07:45:59 PM »
I'm sure the forks have wider spacing, don't know about the hub though.
Offline YogiBear
« Reply #4 on: December 19, 2009, 08:33:49 PM »
the good news is, the DOHC CB750K forks are 35mm just like the SOHC ones. I know ive seen it done, let me try and find the pic of the bike im talking about. Might help you out some.
1974 Honda CB750K4        1973 Honda CB500 Four
Offline YogiBear
« Reply #5 on: December 19, 2009, 08:56:51 PM »
Ta Da, here you go: this is a 78 CB750K with a DOHC K front end, im not sure about the triple tree or what exactly he did, I just ran accross the pics. (sorry if im stealing pics of a member's bike)
PS: all the DOHC 750K front ends are the same from 79-82. (minus 81, and 82 for air assist forks, and 82 for dual piston caliper)
« Reply #6 on: December 20, 2009, 08:11:48 AM »
Does that laced wheel use a 5 bolt disc?
Offline YogiBear
« Reply #7 on: December 20, 2009, 01:12:41 PM »
Yes, the DOHC front wheel uses five bolts to hold the disc.
« Reply #8 on: December 20, 2009, 01:43:38 PM »
Will it work for 77/78 F  750s with 5 bolt discs?
Offline YogiBear
« Reply #9 on: December 20, 2009, 02:05:14 PM »
Hmmm, that I dont know. I *think* they might bolt up, but you might run into problems with the spacing for the caliper, etc. I just sold a set of those year F forks, and wheels. :/
Offline GAsohc4
« Reply #10 on: December 20, 2009, 02:41:35 PM »
hmm guess I'll have to wait for the wheel to get here, hope I can just swap some stuff out and run it, but I have made custom spacers before... it sucks
Offline YogiBear
« Reply #11 on: December 21, 2009, 02:56:33 AM »
Let us know how it works out for you. Im sure you can make it work.  ;)
Offline YogiBear
« Reply #12 on: February 15, 2010, 09:00:12 PM »
Hey, I ran accross this link: http://caferacer.net/forum/post.asp?method=ReplyQuote&REPLY_ID=72329&TOPIC_ID=9125&FORUM_ID=4
The guy is building a SOHC 750K and hes got a DOHC front end on his too. Maybe you could contact him through the site if  you need help with your swap?  ;)
