Both look like k3-up stock calipers, with the right side caliper simply a turned around version of a left hand one. Put another way, it was (and is) possible to mount a left caliper in reverse for mounting on the right side. Two standard caliper kits should be all you need to rebuild them. The dual disc conversion article found elsewhere on this sight (FAQ?) will cover this in detail.
