Author Topic: 1975 cb 550 - Still need help with Piston Ring Gap please  (Read 3424 times)
Offline elquenada
« on: January 01, 2010, 08:47:20 AM »
I posted a slew of questions yesterday but got no response so im crossing my fingers someone will help out with this one.  im guessing yesterday was probably not the busiest day on the forum and on that note...Happy New Year Everyone!!! ;D
Anyway, back to my problem.  My pistons are all cleaned up, my bore has been deglazed and im ready to install a fresh set of Honda standard-size rings.
What do you think of these ring gap numbers:
The top ring (the one with the light gray/crome band right?) measured .013-.014 in all cylinders top and bottom.
The Second ring measured .011 in all cylinders top and bottom.
The 3-piece oil ring rails had a gap larger than my largest feeler gauge (.023)
will i need to file these rings or should I just install them?
1975 CB 550
"A veces lo que es contra lo justo
por la misma razón deleita el gusto"
Lope de Vega
Offline Redman
Re: 1975 cb 550 - Still need help with Piston Ring Gap please
« Reply #1 on: January 01, 2010, 10:49:03 AM »
You need to measure the bores, top, center and bottom. You also need to measure your piston diameters at the skirt. I don`t have a 550 manual, but your readings indicate a lot of wear. You will most likely end up with low compression if you put it back together with what you have.
Offline elquenada
« Reply #2 on: January 01, 2010, 11:12:11 AM »
I did measure the bore and piston skirts and they were in spec according to the manual. Compression was about 150 in all cylinders before I took it apart.
The serviceable limit according to the clymer manual is:
Top Ring:       .028
2nd Ring:       .028
Oil Ring:        .043
My gap measurements upon reinspection of bottom and top of cylinders:
Top Ring:  .013
2nd Ring:  .011
Oil Ring:  .025
« Last Edit: January 01, 2010, 12:25:26 PM by elquenada »
1975 CB 550
Lope de Vega
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #3 on: January 01, 2010, 12:09:48 PM »
The manual should specify a minimum and maximum gap for each ring.  I'm assuming you're listing the max.  Does it say anything about the min gap?
If ur measured gap is less then the specified min gap, then yes, file a wee bit off the end of the offending ring until your gap is slightly larger then the min.  Be careful as rings are easily broken!
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline elquenada
« Reply #4 on: January 01, 2010, 12:12:06 PM »
thats actually why im writing.  I cant find a minimun ring gap in the clymer manual or the pdf of the original honda manual.  I guess I will have to look a little harder cause I dont see it anywhere.  thanks for the response.
1975 CB 550
Lope de Vega
Offline elquenada
« Reply #5 on: January 01, 2010, 12:24:55 PM »
ok.  so i guess im going blind or something cause I just found what I need to know in the service manual pdf.  I guess I wasnt looking in the right place.  this is what the manual says:
according to those specs my top ring seems to be on the top end of the standard value spectrum but otherwise I think im good to install without filing.
1975 CB 550
Lope de Vega
Offline Whaleman
« Reply #6 on: January 01, 2010, 02:24:43 PM »
No need to file. Dan
Offline elquenada
« Reply #7 on: January 01, 2010, 03:20:28 PM »
dan.  thanks for the confirmation. sometimes i have numbers and im still paranoid about proceediing.
1975 CB 550
Lope de Vega
