Somewhere at the back of my mind (and I'm going back 25 years or more for this) I seem to remember a "cure" for discoloration to the pipes - especially when they're new (-ish)....Heavy guage Copper wire bound in tight turns around the pipes, as close to the cylinder head as possible. It would need probably 6 inches or so for each pipe.
The theory being that heat is transferred to the copper wire more easily than to the steel of the pipe(s), thus dissipating the heat more readily and keeping the pipes at a cooler temperature. This (supposedly) stops the pipes from discoloration until a few hundred miles have been put on them (can't remember just how many - 500 or so? I guess it would look like hell for as long as the wire was wrapped around the pipes, but if it worked, they'd be no problem thereafter.
Anyone chime in on this, or have tried it?
Seabird
