Author Topic: stock idle screw setting?  (Read 1222 times)
Offline 000jeremy
« on: January 26, 2010, 02:02:27 PM »
Can anyone tell me the stock idle screw (aka air screw?) setting for my 77 cb550f with stock keihin type 1 carbs?  As in how many turns out?
Thanks!
Jeremy
Offline Deltarider
  • I'm back
Re: stock idle screw setting?
« Reply #1 on: January 26, 2010, 02:09:33 PM »
For the CB550F2 '77 the book says 11/2.
Source: Honda Workshop Manual CB500-550 p.189
« Last Edit: January 26, 2010, 02:17:23 PM by Deltarider »
CB500K2-ED Excel black
« Reply #2 on: January 26, 2010, 02:39:28 PM »
Agreed. 1 1/2, +/- 1/2.
Only applies if you are using all stock components like air filter and exhaust, though.
Offline 000jeremy
« Reply #3 on: January 26, 2010, 03:41:27 PM »
hmmm, I am not.  re-jetting due to pod filters and about to put everything back together.  Would you reckon that this would require a -1/2? or do I have that backwards?
« Reply #4 on: January 26, 2010, 03:54:01 PM »
With pod filters (you glutton for punishment, you), you will most likely have to turn them in to make the mixture richer.  How much depends on your particular brand/style of pod filter, and how much back pressure the exhaust helps your idle mix.
The effect will be measured by how much sudden-open-throttle-twist your engine set up will effectively respond to.  At low RPM under load, up to 1/2 throttle twist should give smooth, reliable acceleration.  More than that and you can expect a wheeze/stumble until you back off throttle.
If you turn the pilot screws in too far, then the spark plugs will collect soot at idle, leading to eventual misfires.
