Author Topic: How to get rust out of tank?  (Read 1287 times)
Offline Duke McDukiedook
  • Space Force 6 Star General
« on: January 29, 2010, 07:37:05 PM »
Any recommendations on what I should use to etch and get the rust out of an '86 VFR750F fuel tank. I just scored one on feebay and the rust is worse on the upper part of the tank than the lower. Should I just try vinegar for the first go around and see what that does?
What kind of vinegar should I use for this experiment?
After I get it relatively clean, would it be OK to red-kote the tank with the internal piping for the reserve/main petcock? Or would it possibly clog the intake pipes when I have the radiator guy do it?
Offline kirkn
Re: How to get rust out of tank?
« Reply #1 on: January 30, 2010, 10:18:51 AM »
Tank cleaning threads are ALMOST as volatile as favorite oil threads...  :)
My current favorite is the vinegar route.  I cleaned a severely rusted, severely varnished CB200 tank with it and it cleaned it right down to beautiful gray steel.
I removed the zinc / aluminimum petcock because the mild acid will eventually damage it.  I made a patch for the petcock opening with plain flat bar stock and a homemade gasket.  I filled the tank with straight, pure white distilled vinegar, right from the grocery store at $2 a gallon.  It sat in the tank for 3 or 4 days and was already so contaminated that I dumped it out and did a repeat treatment for another 3 ~ 4 days and it absolutely cleaned the tank a treat.
When you pour it out, however, that raw steel will flash rust right before your eyes, so I rinsed it with about a quart of gasoline swished all around and dumped out.  I got only a slight bit of 'yellowing' but not a spec more.  I've not had a single problem in the several months / 500 miles since.
In my case, one nice thing is that this treatment will not damage the paint, which was important to  me as this was an excellent-condition, original paint tank that I wanted to preserve.  Just terrible internal rust, and at least 1/4" thick varnish goo in the bottom.
Here's a link to the thread where I documented this over on the HondaTwins forum.  http://www.hondatwins.net/forum/viewtopic.php?f=19&t=1376&st=0&sk=t&sd=a
Good luck with it, however you choose to go.
Kirk
« Last Edit: January 30, 2010, 10:23:40 AM by kirkn »
« Reply #2 on: January 30, 2010, 11:32:34 AM »
Hmmm... I'll have to find a way to plug the holes in the petcock/fuel switch area when I do this, these tanks are way different than 70's style tanks.
Offline mgbgt89
« Reply #3 on: February 01, 2010, 03:33:49 AM »
I can vouch for the vinegar method. HEET works well to dry all the moisture out and keep it from flash rusting.
Online Alan F.
« Reply #4 on: February 01, 2010, 06:00:16 PM »
I haven't heard that one before and it never ocurred to me, but that's the best damn idea I've read tonight!
Cheers Mgbgt89
-Alan
