Author Topic: carburetor issues  (Read 882 times)
Online scottly
carburetor issues
« on: February 11, 2010, 02:33:06 PM »
One of the things I noticed when I first started lurking here was that it seemed there were a LOT of carb problems involving rich/flooding carbs; in fact this of one of the reasons I became a member.
Around '83, I bought a K7 with 5300 miles on the clock as a parts donor. When the seller fired it up, it ran like crap. A quick sizzle test on the exhaust pipes confirmed 2 dead cylinders, and then I noticed gas overflowing from the carbs feeding those cylinders. Cool, let me bargain the price down, and I had lots of experience with carbs, so I wasn't worried about it.
When I got the bike home, I yanked the bowls off, inspected and cleaned the needles and seats, and checked the float levels. Didn't find anything wrong, but then, it doesn't take a very big piece of anything to keep a float needle from sealing.
I buttoned it back up, turned on the gas, and after a minute or so, the gas came dribbling out. What heck!?? Took it apart, checked everything again, also making sure the floats weren't rubbing on the inside of the float bowls. Dribble dribble, toil and tribble. I pulled one of the bowls back off and turned on the gas, then lifted the float with my finger until the fuel stopped. Everything seemed fine. Put the bowl back on, yup, dribble dribble. Grrrrr! This was becoming a quest! I removed one of the floats and put it in a can of gas, and the pivot end of the float went straight down, and the other end poking up out of the gas, kind of like an iceberg. I then hooked a piece of wire into the pivot and raised it up until the float was horizontal. The top of the float was barely level with the gas. I decided then the plastic float didn't, at least not enough.
« Last Edit: February 11, 2010, 02:37:15 PM by scottly »
Offline my78k
Re: carburetor issues
« Reply #1 on: February 11, 2010, 04:03:41 PM »
To be honest I have no clue how much should be floating and how much shouldn't be. So I can't help there...
One other thing I would check though just to rule it out would be the overflow tubes/ They have been knowm to develop hairline cracks as well giving the impression that the floats are sticking.
But by your description I am sure you are headed in the right direction.
Dennis
« Reply #2 on: February 11, 2010, 04:33:50 PM »
If the overflow tubes are good, you can always try switching floats with the two that didn't overflow as another step to troubleshooting.
I take it this is a 750? Are the seats replaceable in those PD carbs? For sure you can install new needles and something I've done before in a pinch is use a Q-tip and some valve grinding compound to "dress" the needle seat. Of course the carbs should be disassembled in order to clean well afterwards.
Good luck
Online scottly
« Reply #3 on: February 11, 2010, 04:39:48 PM »
What I'm trying to say here is that I suspect a whole lot of these carb problems are caused by the solid plastic floats that don't float like they should. In a lot of these cases it seems like after checking the mechanical float setting, as I did, people start looking at tappets, and timing, and ignition, and advance. If the plugs are black and sooty, it's rich. If it's normal in color, but wet, then suspect an ignition problem (hey, no fire, no soot).
