Author Topic: what octane gas?  (Read 1593 times)
Offline cadler
what octane gas?
« on: January 11, 2006, 02:12:59 AM »
What is the lowest octane gas you can use in your cb750's?
Thanks
Craig
Offline Bob Wessner
  • "Carbs Suck!"
Re: what octane gas?
« Reply #1 on: January 11, 2006, 02:20:40 AM »
Assuming stock engine, regular, 87 US octane is the recommended fuel.
Offline cbjunkie
  • ...know what i'm sayin'?
« Reply #2 on: January 11, 2006, 02:21:14 AM »
this topic has been flogged over and over - try a search and let the fun begin...
insomnia, bob?
1971 750K1
1972 CB350 (deceased)
sometimes naked, sometimes mad -
now the poet, now the fool -
thus they appear on earth,
the free men.
« Reply #3 on: January 11, 2006, 02:24:02 AM »
Depends on the country, as octane ratings may be different.  But, if you have a stock bike, Honda made them to run on regular fuel.  The owners manual for the 77 CB750F says 86 octane or higher pump octane and 91 or higher for RON ratings.   Current US ratings for regular are about 87 octane (average of RON and MON ratings).
« Last Edit: January 11, 2006, 02:29:48 AM by TwoTired »
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #4 on: January 11, 2006, 02:24:44 AM »
No, just an aged basset hound. Her hours are my hours.  ;D
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
« Reply #5 on: January 11, 2006, 05:06:54 AM »
SOHC4 Member #2393
1971 CB500K0 (US Model)
All modern bikes now gone...
Offline Gordon
  • 750K1, 550K2
« Reply #6 on: January 11, 2006, 07:00:15 AM »
Yeah, let's not bring this one up again.  It's likely to get more heated than a "what oil should I use" thread. :o
Offline Jonesy
  • Shop Rat
« Reply #7 on: January 11, 2006, 07:11:27 AM »
What I found out was the main source of confusion is the owner's manuals. If you look in ones printed before the U.S. (R+M)/2 rating system was adopted, they say one thing. Ones printed afterward say another. The change occurred somewhere between 1973-'74.
Offline 78 k550
« Reply #8 on: January 11, 2006, 07:15:57 AM »
I run 87 in my bike's.
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
Offline Gordon
  • 750K1, 550K2
« Reply #9 on: January 11, 2006, 07:20:53 AM »
Had that same problem with my '74 VW van back when I was just a young pup and didn't know any better.  The info plate on the engine said to use 91 or higher octane fuel, so that's what I used for the first four years.  I was kind of pissed when I realized I had been wasting my money and that 87 was the current equivallent! >:(   Then again, that was back when a gallon of premium was going for half what a gallon of regular costs today.  Those were the days! ::)
eldar
« Reply #10 on: January 11, 2006, 07:30:17 AM »
87 works fince if you have a standard engine. What I would like to have a definative answer for is what octane to use if you have an 836 kit.
Do you need premium or can you use the midgrade? Midgrade is 89 - 90 octane.
Offline ProTeal55
  • Est1968.com
    • Joe's Barbershop Chicago
« Reply #11 on: January 11, 2006, 07:41:55 AM »
My stock bike runs no different on 93 as it does on 87.
If the bike doesnt have more compression , their is no need to run a higher octane fuel.
My last racecar ran on 116  ;D
eldar
« Reply #12 on: January 11, 2006, 07:49:01 AM »
The standard 836 raises the comp to about 10.25:1 or so.
Offline dusterdude
« Reply #13 on: January 11, 2006, 10:02:18 AM »
eldy,try 89.the aluminum head will let you run higher compression without raising your octane requirements,however with an air cooled engine you may have to go up to 89 or maybe 93 or so.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
