Author Topic: reinstalling cam  (Read 566 times)
Offline MasterChief750
  • Detonation
reinstalling cam
« on: February 20, 2010, 04:21:20 AM »
ill be putting my cam back in eventually but i wanted to clear up a question i had. you ime it off of 1-4 tdc but after you have te cam off and you have rotated the engine how do you know if 1 or 4 is at tdc or does it not matter?
1976 CB750 K - Drag Bike
I AM THE STIG
Sam is THE STIG
he said i can be STIG3 tho
Offline Deltarider
Re: reinstalling cam
« Reply #1 on: February 20, 2010, 04:30:20 AM »
1 and 4 are both TDC at the same time, so it doesn't matter.
CB500K2-ED Excel black
« Reply #2 on: February 20, 2010, 04:33:39 AM »
the cam spins at one half speed of the crank shaft,,the line up slot on the cam can be rearward on the head,,or forward as per instructions.pistons 1+4 rise and fall together,,as do pistons 2+3,the spark also occurs as say 1 fires and 4 exhausts and visa versa,a wasted spark,the same for 2+3.um,not trying to confuse you.
« Last Edit: February 20, 2010, 04:39:29 AM by dave500 »
  • Detonation
« Reply #3 on: February 20, 2010, 04:46:37 AM »
i understad what you are saying glad i dont have to tear into the cas or something to make sure a piston is on fire or something. i figured that it didnt matter but i didnt want to screw it up.
I AM THE STIG
Sam is THE STIG
