Author Topic: Clutch removal  (Read 683 times)
jeez
Clutch removal
« on: March 06, 2010, 05:27:33 AM »
Ok, here is a stupid question....The engine is out of the bike, following the disassembly process in the manual, you take loose the alternator side of the engine first, then you pull the points and clutch.  The manual says to put the transmission in high gear to remove the clutch nut.  Unfortunately the engine won't shift into gear and the trans just spins freely, which keeps me from loosening the clutch nut.  Does anyone have any suggestion on how to block the trans from spinning to allow for the clutch removal?
Offline 05c50
  • 05c50
    • Classic Motorcycle Solution
Re: Clutch removal
« Reply #1 on: March 06, 2010, 05:48:38 AM »
If you can get access to an impact gun (air or electric) that will loosen the nut.
.........Paul
Wear a helmet,the life you save may be your own.Ask me how I know.               CB650C,CB550F,GL1000,CB750A
Offline MFHP
Re: Clutch removal
« Reply #2 on: March 06, 2010, 03:12:04 PM »
whats the reason for the trans not shifting? Should be possible if its rotating
Offline KB02
Re: Clutch removal
« Reply #3 on: March 07, 2010, 05:54:23 AM »
This is what I did on my engine:
Basically I just had a wide piece of aluminum that I cut three holes in. Two to mount to where the pressure plate mounts and then one big one in the center to fit my ratchet and clutch tool through. Not really what the post were meant for, but it worked for me.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
