Author Topic: 1972 CB350 4 front brakes.  (Read 2039 times)
Offline anton1117
« on: March 11, 2010, 01:43:55 PM »
Hi.
I have a 1972 CB350 4. The front brake reservoir is leaking, and the front caliper needs rebuilding or... replacing. Is this difficult? Should I try to replace the whole front brake assembly with a good one, or rebuild the one I have? Can you give me a good supplier of parts for this job, if you feel a rebuild is better than a replace?
Any advice or input is much appreciated!!!!!!
Re: 1972 CB350 4 front brakes.
« Reply #1 on: March 11, 2010, 02:16:03 PM »
brake pads, rebuild kits, diaphragms, pistons, piston seals, and new ss brake lines can be found at david silver spares.
http://www.davidsilverspares.co.uk/parts/part_2845/
dont skimp...stopping fast is almost as important as going fast  ;D
nice bike...btw!
« Last Edit: March 11, 2010, 02:21:12 PM by flybox1 »
Offline hoodellyhoo
  • CB350F
« Reply #2 on: March 11, 2010, 06:41:42 PM »
It's deffinitely worth your time to disassemble and repair what you have. It's easy enough to do. Do a search on the site and you will find lots of info. The braking systems on all the sohc4 are basically the same.
