Author Topic: caliper piston seal (help)  (Read 4604 times)
Offline 75cb550 (kyle)
  • so you're calling me a
  • KEEP YOUR BOOGER HOOK OFF THE BANG SWITCH
    • My Album
« on: March 15, 2010, 02:35:57 PM »
i put a new honda seal in the 550's front caliper bore a few months back. the bike has sat since then but now im trying to get her road ready...
however, the seal is leaking. i pulled the piston back out and i cant see anything wrong with the seal or bore. any one run into this or have any ideas.
thanks....
Offline Duke McDukiedook
  • Space Force 6 Star General
Re: caliper piston seal (help)
« Reply #1 on: March 15, 2010, 03:13:58 PM »
Did you possibly get a little overzealous in your cleaning/scraping of the seal groove?
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #2 on: March 15, 2010, 04:19:51 PM »
Or underzealous in cleaning the seal groove and left some crud behind?
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline Johnie
« Reply #3 on: March 15, 2010, 04:46:55 PM »
Did you lube that seal and piston before you put the piston back in?
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline JS550
  • the artist formerly known as
  • IAFF local 1307
« Reply #4 on: March 15, 2010, 04:48:18 PM »
The first time I did it, I sheered the seal when I reinstalled the piston. Not enough lube.
If you're worried about how many calories are in beer, is losing weight really your biggest problem?
Offline Johnie
« Reply #5 on: March 15, 2010, 04:54:02 PM »
You narrowed it down to 3 things: bad seal, piston with pits, seal groove bad or dirty. I would do it again with another seal if you determine the piston is not overly grooved. Once it starts leaking you have to change something. I do not think cleaning and putting the same seal back in would be the answer. Unless you feel there is a ton of dirt on the seal? Did you use OEM or aftermarket seal?
Oshkosh, WI  USA
Offline JS550
  • IAFF local 1307
« Reply #6 on: March 15, 2010, 05:15:44 PM »
You might tear or mess up the seal taking it out anyway. I would just plan on a new seal. Again.
    • My Album
« Reply #7 on: March 16, 2010, 06:15:19 AM »
thats what i was thinking. and yes it was a honda seal.... ill need to pull it out and give it a good look. i cleaned out the groove with a pick i think. i tried not to scrape anything too hard but that could be it. what did you guys use to lube the seal. im pretty sure i lubed it but i cant remember what i used. that could be the whole problem.
Offline Johnie
« Reply #8 on: March 16, 2010, 01:12:30 PM »
To clean that groove I did not use a pick, but instead used a Dremel with a brass brush on it. The lube I used was high temp silicone for brake applications.
Oshkosh, WI  USA
    • My Album
« Reply #9 on: March 16, 2010, 02:05:39 PM »
k. i actually think i have another seal for it. i will give that a try.
thanks...
« Reply #10 on: March 16, 2010, 03:27:59 PM »
I used Brake Assembly lube, McKay brand if I remember right.
http://www.airosol.com/50600.html
« Reply #11 on: March 16, 2010, 03:33:11 PM »
That is what I use, as well.  I do NOT want any silicone inside mixed with the brake fluid.
The silicone lube is for a water shed on exposed-to-atmosphere portions of the caliper.
There is a caliper rebuild walk though in the brake FAQ.
Offline Johnie
« Reply #12 on: March 16, 2010, 04:09:12 PM »
Wish I knew about the silicone earlier. Oh well, I will report back if I have caliper problems. What I used was NAPA Sil-Glyde. Says "non-melting, non-freezing, non-gumming and weatherproof. For brake pads, calipers, rubber boots, etc. Eliminates caliper sticking." This was all on the tube from NAPA. I will use the McKay in the future. I figured out why I used the silicone grease. My Honda shop manual says, "use silicone sealing grease (temperature 67-392F). Do not use molybdenum grease known as brake grease". I am not saying the Honda manual is correct now days since it was written in the late 60's, but that is where I got the information. I also note that in the FAQ area this is what I found: "Clean all the exposed surfaces of the piston and caliper with the cleaning solvent. Using the High Temperature silicone grease, coat the back of the brake pad puck, the piston face, and the caliper socket for the puck. Don't get silicone grease on the fiction surfaces of the brake pads! " If this is incorrect information we should correct it there.
« Last Edit: March 16, 2010, 04:22:53 PM by Johnie »
Oshkosh, WI  USA
« Reply #13 on: March 16, 2010, 06:01:59 PM »
And they are Fcuking liars, too, IMO.  It only contains silicone, is NOT pure silicone.  And, is in no way proper for use on the SOHC4 caliper seal.  I did an oven test on it years ago, it smoked off and left a brown tar residue at around 300F, if I recall correctly.  There have been several prior threads on this stuff.
This stuff ruined my brake pads as it creeped/ran onto the pads and caliper surface, losing most of the braking action.  What little silicone was there permanently ruined my brand new pads.
Yes.  Search the forums for DOW Corning Hi temp Grease.  This stuff is unworldly.  I couldn't get this stuff to show any change in characteristics up to the limit of my 500F oven.
No, that stuff still lubes at hi temp, but oozes, creeps, and runs, needing some kind of lip seal for containment.
The manual is still correct, I believe.
I wrote that in the FAQ.  I'm sorry you misread it.
The seal itself gets Brake parts assembly lube.
The exposed surfaces are those exposed to the atmosphere/rain/contaminants.  The caliper design has no way to keep water from getting getting behind the brake puck, the non-brake fluid side of the piston, the caliper cylinder wall and side of piston.  A coating of silicone grease on those areas repels water in this area preventing corrosion.
How would you recommend the prose be changed for proper reading?
Offline Johnie
« Reply #14 on: March 17, 2010, 07:32:07 AM »
TT...tell me if I have this correct as I do admit I am trying to grasp it. The Dow is used on the caliper wall from the seal ridge out including the edges of the pads and the area under each pad. Dow is also used on the piston & puck area once it has been started into the seal. The McKay brake assembly lube is what I should use on the seal only. Do I put McKay lube on the caliper wall on the opposite side of the seal which is in contact with the DOT 3?
Lastly, can I just clean my new seal and reapply the McKay with no problem or do I need a new seal now? The bike has not been driven since the seal was installed 2 weeks ago. I have ordered the Dow but am still trying to find the McKay assembly lube or something which will work...any other product you recommend?
« Last Edit: March 17, 2010, 09:14:49 AM by Johnie »
Oshkosh, WI  USA
« Reply #15 on: March 17, 2010, 10:08:19 AM »
By George, I think he's got it!   ;D
If you are going to store it on the shelf for ten years, probably.  But, in service the interior walls are wetted by the the DOT3.  The proper assembly fluid kind of dissolves in DOT3.
Silicon can only be flushed, as it dissolves in nothing.  The rubber is porous, so there is still silicon in it.  I don't know for sure reusing it will cause a problem.  But, I wouldn't reuse a seal contaminated in that way, if I could avoid it.
Sorry, I know the proper fluid is hard to find these days.  But, I know of no proper substitute in this application.  If pressed, I would just use DOT3 sparingly on the seal.  However, that portion of the seal that faces the atmosphere, or more importantly the metal it whets, will be prone to corrosion, as DOT3 absorbs water.  And of course, the atmosphere has oxygen in it to promote corrosion.
Honda got much better at designing calipers to withstand weathering without the special greases and fluids.  But, it wasn't until after this design.  Still, this one works well if maintained correctly.
Offline Johnie
« Reply #16 on: March 17, 2010, 11:05:30 AM »
Excellent...I got the Dow from eBay. Does anyone have a source for the McKay assembly lube? If not, I will just use the DOT 3 on the seal surface per TT's message. The local auto parts store has some made by Raybestos, but I am not sure what it contains yet.
« Last Edit: March 17, 2010, 11:08:21 AM by Johnie »
Oshkosh, WI  USA
« Reply #17 on: March 17, 2010, 01:35:42 PM »
I found Dow Corning Hi Vac Grease 150 gram tube on Amazon.com for $49.02. Is that about what you paid?  Any better deals out there?
Sure.
Is it hard?
« Reply #18 on: March 17, 2010, 01:46:58 PM »
Both these work for the caliper seal.  And master cyl rebuilding, too.
Offline Johnie
« Reply #19 on: March 17, 2010, 01:56:31 PM »
My Dow cost was $24 for an unopened 5 oz. tube including shipping.
« Last Edit: March 17, 2010, 02:10:18 PM by Johnie »
Oshkosh, WI  USA
« Reply #20 on: March 17, 2010, 02:06:38 PM »
5oz = 142g so you got the best deal so far!
Sure.
Is it hard?
Offline Johnie
« Reply #21 on: March 17, 2010, 02:08:44 PM »
None of my parts stores here in WI have the Raybestos assembly fluid, but I think this is it on Amazon. No picture but I think this is it for $15.
http://www.amazon.com/Raybestos-BAF12-Brake-Asembly-Fluid/dp/B001ANJ2GE
Oshkosh, WI  USA
    • My Album
« Reply #22 on: March 17, 2010, 02:09:50 PM »
ill be checking autozone/napa tonight... im glad i asked.... i never would have thought about it....
« Reply #23 on: March 17, 2010, 02:14:30 PM »
Yes, BAF-12 is the what the Raybestos bottle has on it.
Offline Johnie
« Reply #24 on: March 17, 2010, 02:43:13 PM »
My Autozone, NAPA and United Parts do not carry Raybestos. The Amazon bottle has the TT approval so I will get it tonight.
TT - thanks once again for all your time on this topic. I luv you man!!!  ;D
Oshkosh, WI  USA
