Author Topic: It's one thing after another (help needed, again!)  (Read 867 times)
Offline Ketch
« on: April 02, 2010, 09:15:00 PM »
I have a bolt stuck in my cylinder head.
Any suggestions on how to remove it?
1981 Kaw KZ1000M
1976 Honda 550/4
1992 Suzuki GS500E
Re: It's one thing after another (help needed, again!)
« Reply #1 on: April 02, 2010, 10:19:12 PM »
First you must find a lot of good rags to plug up all those nearby holes.  ;D
Then, get a screw extractor for the bolt size (Ace Hardware carries them), get the one that comes with the drill bit. Drill the hole into it, then remove all the filings. Stuff new rags into the holes, away from the working area if you can, so you can heat up around the bolt with a torch. Then back the screw out with the extractor bit.
Offline Kframe
  • Life is good!
« Reply #2 on: April 02, 2010, 10:46:54 PM »
Yep that's pretty much the only right way.  (Well, short of EDM, but that's not necessary here.)
If you've got a shop vac, buy a long neck small funnel at NAPA and tape the bell to the hose, and now you have a powerful small suction tip.
Use that to vac away filings as you drill.  Get the nozzle right up there.
Another trick is to goop grease all over the area to be drilled, to catch the filings and hold them in a big gob.
-K
2007 Triumph Bonneville T100, ARK'd, Pods, TOR's, Napoleon's, Innovate G5 Air/Fuel Gauge, Ignition Relocation by D9, Stebel Nautilus, Avon Roadriders
1984 Honda Shadow VT700c, Stock
1974 Honda CB550K, In rehab
1986 Honda Helix
Offline Ketch
« Reply #3 on: April 02, 2010, 10:48:06 PM »
got it out with a regular everyday 1/8 inch metal drill bit drilled into it and then used a 3/16inch in reverse and the heat and pb blater and it came right out love it thanks Bucky And honda man.
  NOW anyone got a good place to get the replacement bolt?
1981 Kaw KZ1000M
1976 Honda 550/4
1992 Suzuki GS500E
Offline Ketch
« Reply #4 on: April 02, 2010, 10:50:47 PM »
just so you know i used the bunched up rag technique
1981 Kaw KZ1000M
1976 Honda 550/4
1992 Suzuki GS500E
Offline Indiana John
« Reply #5 on: April 02, 2010, 10:53:37 PM »
For stuff like this, I like to use my left-handed drill bits. More often than not, they will drill in a ways then grab and back the screw right out. We just did this with a couple of stripped screws on my Gold Wing project.
IJ
IJ
76 CB550
75 CB750
76 GL1000
« Reply #6 on: April 04, 2010, 10:11:26 AM »
Most bike shops carry the bolts: go to KawasakiPartsNation.com online, look up the Honda parts fische for your bike, find the bolt in the exploded views and write down the length and size. Nowadays, even Ace Hardware is carryin quite a bit of metric stuff than can work OK (heck, just look at all the metric chrome on MCrider's beautiful build: it's all Ace Wardware stuff!).
