Author Topic: just to be doubly sure (550 w/ 650 cam question)  (Read 835 times)
Offline Ayrity
« on: April 24, 2010, 07:01:29 AM »
a 79 cb650 cam shaft happened upon me for 10 bucks, looks to be in good condition. I am planning a late summer spruce up of the engine internals, while I'm in there, can I just drop the 650 cam into the engine direct swap? use the gear on the 650 shaft? and how much will this (to steal hondaman's wording in the tips section) "wake up" the mid power? thanks guys
1976 Honda CB550k
Offline Gordon
  • 750K1, 550K2
traveler
Re: just to be doubly sure (550 w/ 650 cam question)
« Reply #2 on: April 24, 2010, 07:19:25 AM »
It's a drop in cam....said to work well.
550 Tachometer will not work with 650 cam.  Have to get a tach from a 650.  The gearing inside the tach itself is different.
~Joe
Offline Ayrity
« Reply #3 on: April 24, 2010, 07:37:46 AM »
awesome. all the info I needed to make me confidant. Thanks to both of you!
1976 Honda CB550k
Offline Highwayhigh
« Reply #4 on: April 25, 2010, 04:46:18 AM »
I literally JUST completed this swap. It was pretty easy. The only real challenging part was the 4 totally seized fasteners I had to deal with. But got it installed, set tappet clearances, and timed the engine (it needed it bad), and then I fired it up. Maybe it's because I'm tired, but to me it sounds a bit meaner. I gotta wait until later to ride it...stupid rain!
Good luck on your swap! It's fun and worth it for such a low cost.
1978 Honda CB550K -
The first of many to come in my horrible motorbike addiction.
