Author Topic: Wiring help  (Read 1144 times)
Offline mycb750k6
  • "res ipsa loquitur"
  • Rocketman
    • photobucket albums
Wiring help
« on: May 22, 2010, 12:53:33 PM »
I'm putting the 71 CB750 wiring back and I have an 'extra' wire. I have a brown wire with female connector coming from the harness into the bucket but there's nothing to plug into it. 71 wiring diagram and wiring FAQ say that brown is Tail Light Power (Main Switch-Tail Light). So why do I have a brown female wire dumping into the headlight bucket?? Anyone know?
co425
Re: Wiring help
« Reply #1 on: May 22, 2010, 01:09:50 PM »
Goes to the brake splitter below the headlight with the brake switch. Just my guess.
Offline 333
  • Time for change
Re: Wiring help
« Reply #2 on: May 22, 2010, 03:26:58 PM »
Tail light power should come from the right handle light switch(comes on with headlights), or the ignition switch(runs tail light when ignition switch is in "park" position).
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline mycb750k6
  • Rocketman
Re: Wiring help
« Reply #3 on: May 22, 2010, 04:34:52 PM »
Yeah thanks.
I'm looking at old man honda's K1 wiring diagram: -> http://oldmanhonda.com/MC/wiring750K1.html
And I don't see anything from the right switch to the tail light. The brown wire goes from the ignition. So I can't figure why I'd have a brown female in my bucket. Remember the K1 headlight doesn't come on unless you turn it on.
Offline Spanner 1
Re: Wiring help
« Reply #4 on: May 22, 2010, 04:49:42 PM »
The brown female would connect to the 'city light' 5w extra bulb in the headlight reflector on European models, so it's spare in your loom.....
Offline mycb750k6
  • Rocketman
Re: Wiring help
« Reply #5 on: May 22, 2010, 05:02:06 PM »
Thank you. I was hoping that was the answer or something like that. How do you people know all this stuff? ???
