Author Topic: CB500 forks - help!  (Read 1360 times)
HondaRog
CB500 forks - help!
« on: May 28, 2010, 12:08:05 AM »
I've taken the forks out of the triple tree to re-oil them, and having done that, reassembled and refitted them, there seems to be no tension in either fork - I can pushg down but they don't spring back. Everything looks OK from the outside.
Somebody PLEASE tell this numbskull what he's done wrong?
Thanks all,
Honda Rog  :-[
Offline fastbroshi
  • Puppet
Re: CB500 forks - help!
« Reply #1 on: May 28, 2010, 12:24:05 AM »
  Are you sure you put the right amount of oil back in?  Is that info in the manual by the way?  While doing so, you have to pump them a couple times to get the air out IIRC.
Just call me Timmaaaaay!!!
HondaRog
« Reply #2 on: May 28, 2010, 12:27:07 PM »
Yeah, 160ml as stated, using the kitchen measuring jug (what else?). Did pump them to see what they felt like, seemed OK - but first time I've ever done owt like this, so no idea what to expect.
Guess I might take them out and start again. Have a feeling I've missed something blindingly obvious, or put them together wrong.
Offline fastbroshi
  • Puppet
« Reply #3 on: May 28, 2010, 02:52:49 PM »
You said there seems to be no tension.  When you pushed down on them, did they return at all?  What weight oil did you use?
Offline Jordan
  • What a Long strange trip it's been
« Reply #4 on: May 28, 2010, 03:22:07 PM »
Allen bolt in the bottom of the lowers locks plunger in place, a spacer on the plunger, spring sits on it, lock nut, compresses spring somewhat,  and cap screws on with an o ring, a drain bolt on outboard bottom legs are about all there is to mess up, my manual calls for 5.2 oz 30wt oil. Hope you figure it out.
Offline fastbroshi
  • Puppet
« Reply #5 on: May 28, 2010, 05:17:35 PM »
30wt?  You sure about that?  20W is used for racing apps.
Offline Jordan
« Reply #6 on: May 28, 2010, 06:28:07 PM »
I was kind of wrong on the fork oil thing, the manual on page 17 says SAE 10w30 160cc (5.4 oz). 1973 CB500K? Four cyl.
« Last Edit: May 28, 2010, 06:36:29 PM by Jordan »
« Reply #7 on: May 28, 2010, 06:41:30 PM »
Just a shot in the dark: Loosen all the triple clamp bolts, and make sure everything is aligned and centered before you clamp things back down. The forks may be twisted, and binding.
HondaRog
« Reply #8 on: May 29, 2010, 09:48:48 AM »
Thanks all. Further investigation shows that the RH lower may be distorted - there's a chewed off bolt where the mudguard fits, and I reckon PO has damaged the lower leg in trying to get the stub out - the tube only slides freely in about 6", then sticks pretty tight. LH leg feels fine.
I'm in the UK - anyone know of a LH leg for sale?
HondaRog
Re: CB500 forks - help! SAGA OVER!
« Reply #9 on: June 03, 2010, 11:00:09 AM »
Sorted, thanks to Newport Classic Motorcycles (07859 814026). Bike is now on the road and feels FANTASTIC to ride! Woo Hoo! Thank you Mr. Honda!  :) ;) ;D
