Author Topic: '76 750F frame & '76K motor: sprocket alignment?  (Read 587 times)
Offline Tugboat
  • Puppet
    • PseudoMoto
« on: June 03, 2010, 08:06:50 PM »
I've looked around but been so overwhelmed by this project - more details on that later - that I haven't found the answer. So here it is:
I have a '76 750F with a bad motor and a '76K replacement motor that I'm going to be putting on the F frame. I know it will bolt on the same, but will the sprockets line up, or will I have to jigger that to make it right?
MANY more questions to come I'm sure as I start taking a look at this motor that's been sitting outside under a carport for a while (not mine - PO's). It's not locked up and seems to shift through all the gears, so I'm hoping for the best. Thanks guys.
Re: '76 750F frame & '76K motor: sprocket alignment?
« Reply #1 on: June 03, 2010, 08:58:55 PM »
Same thing. Bolt it up.
Offline BeSeeingYou
« Reply #2 on: June 03, 2010, 11:36:02 PM »
Maybe the only difference you will find is the K will have a 18 tooth sprocket vs. the 17 tooth of the F.  Either will work fine.  With the 18 you will give up a bit of power but at cruising speed you will be a few hundred rpm lower with less vibration.  For a highway cruiser stick with the 18 but for tearing round town maybe the 17.
