Author Topic: Manual Cam Chain Adjusters  (Read 6611 times)
Offline Big Jay
    • CBRzone
« on: June 22, 2010, 03:22:37 PM »
Offline BLUE71TURBO
Re: Manual Cam Chain Adjusters
« Reply #1 on: June 22, 2010, 03:27:57 PM »
 Where's the " BLUE "  one ?   :'(
Offline Big Jay
    • CBRzone
« Reply #2 on: June 22, 2010, 05:36:46 PM »
Over on our Suzuki site  :D
Offline BLUE71TURBO
« Reply #3 on: June 22, 2010, 08:46:20 PM »
  I WAN'T A BLUE ONE !!!!
Offline kos
    • m3racing.com
« Reply #4 on: June 22, 2010, 09:03:42 PM »
http://cbrzone.com/sohc.html     8)
Nice work....BUT do not over tighten! the cam chain when installing.
KOS
Mark@M3Racing.com
220...221, whatever it takes.
Offline BLUE71TURBO
« Reply #5 on: June 22, 2010, 09:16:07 PM »
 How do you know when it's tight enough or too tight ?   ???
Online scottly
« Reply #6 on: June 22, 2010, 09:28:42 PM »
It's too tight when your chain sounds like this:
 :D
Offline Doctor_D
« Reply #7 on: June 23, 2010, 07:16:12 AM »
Kos:
Is this compatible with your tensioner? (and do you have any tensioners done at the moment? It's the last thing I need to assemble my engine.)
Take care,
David
1978 CX500
1971 Norton Commando
Offline BLUE71TURBO
« Reply #8 on: June 23, 2010, 02:41:18 PM »
Kos:
     ?????  A.P.E. Has them !  Why not buy from our major sponser ?  Just my thoughts...... ::)
Offline Big Jay
    • CBRzone
« Reply #9 on: June 23, 2010, 02:54:11 PM »
Sold out in two days. :o :o
Starting on a new batch right away.
Offline Doctor_D
« Reply #10 on: June 23, 2010, 08:17:36 PM »
[quote author=BLUE71TURBO link=topic=72892.msg809885#msg809885 date=1277329278
[/quote]
It's not an "instead of" question, it was an "in addition to" question.  I ordered a tensioner from McGrew that I'm waiting on, and I asked if the non-spring-loaded setup APE had would compliment it.
As for APE... let's see... I have their crank studs, head studs, lightened crank, etc. It's not like I'm not doing my part. Sheesh  ::)
Take care,
David
1978 CX500
Offline BLUE71TURBO
« Reply #11 on: June 23, 2010, 08:35:53 PM »
  Like i'm supposed to know.  ::)  ;D   Just trying to spread your wealth.   :D :D ;D
  • Moderator
« Reply #12 on: June 23, 2010, 10:53:16 PM »
Jay, make sure you do some blue ones for a very confused Jon to match his blueturbo ;D ;D ;D ;D
Jon, you'll just need the other bit from Mark to have the best in cam chain management systems.
Mark, perhaps you can get some tensioners done in blue and get Mike to do him a billet block with a clear window in the back so it can be seen in Jon's engine. :D :D :D :D :D
It's the big air in your avatar Jon, perhaps some type of altitude sickness. ::)
Sam. ;)
Offline BLUE71TURBO
« Reply #13 on: June 24, 2010, 07:36:14 AM »
  I think i found a solution for my air sickness........
   For some reason the shirt really itches where those patches are located.  ::)
« Last Edit: June 24, 2010, 07:39:22 AM by BLUE71TURBO »
  • Moderator
« Reply #14 on: June 24, 2010, 07:41:07 AM »
Is that really you Jonny, you still look a bit sick. ;D ;D ;D ;D
Sam. ;)
Offline Leino
  • Not much of an
  • in drag racing since 2005
« Reply #15 on: June 24, 2010, 09:36:03 AM »
And what a beautiful site it is...  ;D
Offline kos
    • m3racing.com
« Reply #16 on: June 24, 2010, 12:01:15 PM »
Kos:
APE does not sell my tensioners, only the push rod adjuster.
Mark@m3racing
Offline kos
    • m3racing.com
« Reply #17 on: June 24, 2010, 12:04:01 PM »
[/quote]
THE APE set up should work, but I am concerned about the lack of rubber cushion in at the end of adjuster bolt, like OEM part has and the possibility of customers over tightening the tensioner and thus... the cam chain.
I still need to test this new part out in running conditions.
Mark@m3racing.com
Offline kos
    • m3racing.com
« Reply #18 on: June 24, 2010, 12:05:13 PM »
Kos:
YES, I have tensioners in stock
Mark@m3racing.com
Offline lordmoonpie
    • Moonpie
« Reply #19 on: June 25, 2010, 04:35:31 AM »
You can do this by ear if you fancy a go - if it rattles it's too loose if it whines it's too tight. Install at a reasonable tension and then adjust when running in and out to get your first whine and first rattle then set half way. You gotta be brave to do it this way though :D
I had to do it kinda like this with my CR750 as the hy-vo camchain was too loose using the standard tensioner and a custom slipper tensioner blade, similar to those KOS sells. The engine seems happy!
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
Offline BLUE71TURBO
« Reply #20 on: June 25, 2010, 07:16:25 AM »
  Sounds logical.  Hey i sounded like Spock. I wonder how i'd look with pointed ears ?   :o  8)
Offline kos
    • m3racing.com
« Reply #21 on: June 25, 2010, 07:31:09 AM »
AS per my instruction's included in the slipper tensioner box when I send it out. Let the OEM Honda spring put the pressure on the cam chain...it will be a bit difficult, but not impossible to duplicate this amount of pressure with a screw in bolt. I am working on proper procedure now with a similar tensioner assembly I have mocked up here at the shop. I hope to have the answer later next week.
Mark@m3racing.com
Offline Zaipai
    • My Home page
« Reply #22 on: June 30, 2010, 04:33:44 AM »
These would not work on a 550 would they?
.: Scott :.
Its my Avatar..
75 CB550F  |
Offline City Boy
« Reply #23 on: July 07, 2010, 10:43:51 AM »
Hi gang.The adjustment method I have always used that has served me well is as follows:Remove a tappet cap and turn crankshaft until the now visable rocker shows valve partway open.Loosen chain adjuster lock bolt,turn crank forward slowly while at same time tightening lock bolt.Next,check adjustment by moving crank a  little forward and a little in reverse while observing rocker arm.Adjustment is correct when there is no lag between crank moving and rocker moving.This procedure assumes that auto tensioner is not sticking.If it is,sometimes can be freed up by loosening lock bolt and moving crank a distance in reverse of normal rotation.   Rock On
'52 Kiekhaefer Mercury Rocket Hurricane KG4H
'70 750/RC 1000 Original Owner
'83 1100F
Offline kos
    • m3racing.com
« Reply #24 on: July 07, 2010, 12:59:12 PM »
Very well explained, but you are using a standard tensioner and that has a spring on it... to move tensioner bar in. This new device is a direct contact tensioner with no spring to tension and no pad or dampener to cushion back loading.
KOS
