Author Topic: CB550 can be bored to 672cc!  (Read 8828 times)
Offline volz1fsu
« on: February 10, 2006, 01:12:50 PM »
I am very glad to announce that the 550 engine can be taken to 672cc just by boring.  First you have to obtain 750 sleeves and do some machinework to them as well as the cylinder block and case to fit them.  Once they are in there, boring can be done to fit 836 pistons for a 750 big bore.  Also the stock internal oil lines can still be run without interference.  Compression ratio with that engine combination would yield 10.9:1, on the high side but still should be streetable.  I would definitely recommend an oil cooler to help with the higher temperatures.  You could machine a little of the tops of the pistons to drop that compression ratio down.  I can't wait to build that engine but first I am just going to get my 591cc engine built and work on the 672 in the mean time.  I will provide pictures and more details on all the machine work when I get it done. Better watch out you 750 guys!
« Last Edit: February 10, 2006, 01:14:24 PM by volz1fsu »
Offline n9viw
  • Floyd, '76 CB550k
Re: CB550 can be bored to 672cc!
« Reply #1 on: February 10, 2006, 01:32:14 PM »
Awesome news! Imagine a bike that weighs 2/3rds as much as the 750, yet has power approaching it! Still not a match for a well-tuned modern sportbike, but to get that kind of power out of a vintage metric is impressive. You'll have to keep us up to date about its performance, any problems or issues that crop up like hot spots, reduced plug life, etc.
What kind of intake/exhaust and ignition are you planning to run with this micro-beast? Doing any other changes to reduce downstream damage, i.e. better primary chain, harder shift forks/dogs, beefing frame strength, etc? Will you be changing the cam or doing any head work? Enquiring minds want to know! ;D
Nick
'76 Honda CB550k
'73 Honda CB750k
Offline volz1fsu
« Reply #2 on: February 10, 2006, 07:47:22 PM »
I will be going with the Dyna ignition from www.oldbikebarn.com.  It is rather pricey but worth it.  I don't know what series ignition it is but supposedly it takes samples from every 50 rpm and adjusts accordingly.  I am also porting and polishing the head and I am looking at different cam possibilities.  Megacycle looks to be the way I will go. I will just run my own exhaust that I modified (4-2), It is stock with the exception of my own hand built baffles.
The things I am somewhat worried about are the things that n9viw mentioned.  Hopefully the transmission can take the power as well as the Primary chain since I don't know of any performance modifications or replacements for these.  I can't imagine the frame flexing, I think it is strong enough in stock form however  I may add some strength to it when I decide to have it powdercoated as a preventative measure.  I want to keep the weight of the thing to a minimum, the lighter it is the faster it is.
Right now I know it is physically possible.  Later I will find out if it will last on the road.
Offline oldbiker
  • I HATE RAIN
« Reply #3 on: February 11, 2006, 01:24:25 AM »
I think you would be very unwise to machine anything off the top of the piston. If you make the piston crown thinner you can run into danger of the piston crown melting. If you want to go down this route, it would be better to reduce compression ratio by using a slightly thicker head or base gasket.
Offline volz1fsu
« Reply #4 on: February 11, 2006, 09:07:09 AM »
Also an unwise idea since changing the distance the cam is from the crank will offset the cam timing.  That could be a very bad idea unless a custom grind cam could be made to correct for the timing.  It would be better to machine the pistons tops, mind you that taking off a little will make a lot of difference.  Ceramic coating the crowns after this has been done will prevent burning through.  There is more matterial there than one would think.  The pistons have to be cut for the valve pockets anyway and that would will most definitely cause a thinner area in the piston than what I am proposing.  I wouldn't even bother with it though since 10.9:1 would be fine as is.  I am just making a suggestion to those who would rather not run that ratio.
« Reply #5 on: February 11, 2006, 01:42:01 PM »
You can correct changes in distant with an adjustable cam sprocket (available from Falicon).
« Reply #6 on: February 11, 2006, 01:45:05 PM »
Mike, Did you get the PM. ?
Offline volz1fsu
« Reply #7 on: February 11, 2006, 04:19:20 PM »
Great to know, problem solved. ;D
Offline csendker
  • Chris; '75 CB550 & a Crusty 'ol boat
« Reply #8 on: February 11, 2006, 04:43:09 PM »
There's been a bit of discussion about the quality, or lack thereof, from OBB. Personally, I bought a new clutch cable from them with no problem, but I may be the exception.
http://www.sohc4.us/forums/index.php?topic=7235.msg65605#msg65605
Actually runs --> 1975 CB550-K1
Projects ---> Crusty old boat
Gallery --> http://www.sohc4.us/gallery/v/members/personal/Christopher/?g2_navId=xada3c7ff
« Reply #9 on: February 12, 2006, 03:42:47 AM »
Sounds interesting but i think you will have to change the primary chain every 10,000 or less
Offline cb(r)
« Reply #10 on: February 13, 2006, 05:29:15 AM »
very good and interesting thread.  I am curious to hear how all this work pans out.  good luck with the "BIG BOAR"  it should be an animal when it is done!
Offline cbjunkie
  • ...know what i'm sayin'?
« Reply #11 on: February 13, 2006, 07:55:23 AM »
volz - check this link before you buy from OBB - Dyna for 120...
http://www.z1enterprises.com/
1971 750K1
1972 CB350 (deceased)
sometimes naked, sometimes mad -
now the poet, now the fool -
thus they appear on earth,
the free men.
eldar
« Reply #12 on: February 13, 2006, 08:35:10 AM »
This would be better than useing a "1400cc" 750 with a charger on it. Although the 550 is not 2/3rds the weight of a 750, it is 4/5ths.
Offline volz1fsu
« Reply #13 on: February 13, 2006, 10:52:39 AM »
Thanks for the link cbjunkie!  I still have many websites, like this one, to find for parts and such.  I wish there was some links page or something to handle all these specialty sites.
Even though it is only 4/5 the weight, 100 lbs. is still a world of difference for a cycle with about the same power if not more.
Teach
« Reply #14 on: February 13, 2006, 11:09:32 AM »
Here ya go!
http://www.sohc4.us/forums/index.php?topic=743.0
Offline cbjunkie
« Reply #15 on: February 13, 2006, 11:10:51 AM »
beat me to it teach!  ;D
volz - ya, z-1 is where i got mine from - i'm gonna stick with my stock coils for now, but when i found the thing for 120 i had to get it.
good luck!
cbj...
1971 750K1
the free men.
Offline volz1fsu
« Reply #16 on: February 13, 2006, 11:11:16 AM »
Here ya go!
NOW I'M IN HEAVEN!!!
Teach
« Reply #17 on: February 14, 2006, 07:09:45 PM »
Rob Lloyd
« Reply #18 on: February 15, 2006, 06:46:15 AM »
Why not try the 650 head? It fits right on the 550 engine - you can even use the same cams. If you want to keep it "550" looking, you can use the 550 rocker box. The 650 head already has bigger ports, valves, and combustion chamber than the 550 head. Might be a better match than a heavily ported 550 head. You'd need a 650 exhaust, though.
-Rob
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
« Reply #19 on: February 15, 2006, 08:01:55 AM »
      volz1fsu -- Sounds like quite a beast. I, along with others will be anxiously waiting for details and pics
   I too am wondering about the stress on the primary chain and the trans.  Keep us posted,  Bill
Member # 1969
Offline volz1fsu
« Reply #20 on: February 15, 2006, 08:26:55 AM »
I had no idea that the 650 head would fit on the 550 or that it had bigger valves and ports. Where have I been?  That may be the route I go, but I hate to get a different exhaust system.  The extra power may get the better of me though,.... oh who am I kidding, it always does.
I still am wondering about the primary chain.  I have been thinking a lot about modifying the engine to have a primary chain tensioner. Do the 750s have those, I thought I seen some part like that in a diagram.  I wonder if I could even go the the extreme and have gear to gear contact.  The only downfall to that would be a loss in power to turn the extra weight, and I an almost certain that it is not even possible.  It is fun to dream though.    The stock primary chain will probably last me a very long time anyway and I would be glad to replace it after several years.  The idea of changing it after 10,000 miles, like was suggested, is fine with me.  I only put on 1500 miles last year and I could go a good 6-7 years at that rate.   I think that sometimes people underestimate the strength of steel though.  I have seen it hold together under some very stressful situations.  Then again if there is one flaw in the material, it will come apart.  The tensioner is the best idea because the chain will stretch and that is why it needs to be replaced; at least with a tensioner I can tighten up the slack and postpone an engine teardown.
Offline n9viw
  • Floyd, '76 CB550k
« Reply #21 on: February 15, 2006, 08:32:42 AM »
   Rob, wasn't it your own site that said the 650 bits must be used from tip to toe in order to work properly (650 jugs with 650 crank, pistons, rods, head, etc) due to some difference in the mills? I recall thinking about going the 650 route, but not liking the idea of switching over to a Hy-Vo cam chain (I've not had luck with them in the past).
   Also, if you plunk down a 650 head on a 550 block, you'll run into the same issue some 750 owners have when they bore to 836 and put a 750 F head on, thinking they'll benefit from the F's larger valves- the F has a larger valve chamber, and domed pistons to match, but nobody makes 836 F pistons. The combination of K style flat-top pistons with the F domed-chamber head effectively REDUCES the compression due to extra volume. I'd rather have a head that was flow-matched to the engine than one that just happened to have some of the things I wish it had, but also has some of the things I don't want.
   Volz, the 750 does have a primary tensioner, but it does take up a lot of space. I don't know of any way you could fit it, or any other tensioner, in that tight 550 case, without having to do some really 'creative' milling on the cases.
Nick
'76 Honda CB550k
'73 Honda CB750k
« Reply #22 on: February 15, 2006, 09:17:51 AM »
Has any thought been given to the balance of the engine?
Bigger pistons mean more piston weight, doesn't it?  Isn't the the 550 crank counter balanced for the stock 550 piston weight?  Seems to me that if you don't add the proper weight to the crank counter balances, you will have to significantly lower the red line, at least, so all the moving bits actually stay inside the engine cases.
Rob Lloyd
« Reply #23 on: February 15, 2006, 12:26:55 PM »
If you want to use the 650 crank, then yess you have to use the 650 jugs, cylinder, pistons, and head - or go severly custom with all of the above. But, the 650 head by itself will bolt onto the 550 cylinder. And, yes, the CR will be lower due to the bigger combustion chamber. It has been done before...
And, Lloyd is right. Changing the piston weight significantly will affect the balance of the engine. The counter weights on the crank are weighted to balance the piston/rod assembly. If you can lighten the pistons back down to stock weight (or at least close) then it shouldn't be an issue. Or, you can take the entire reciprocating assembly and have them re-balanced by adding weight to the crank. But, that's expensive. Doing nothing will put higher loads on the main bearings and COULD result in premature wear...
Offline volz1fsu
« Reply #24 on: February 16, 2006, 12:22:06 PM »
Actually you are both wrong,... it happens to me too.
In these four cylinder engines, two pistons and rods are positioned 180 degrees on the crank from the other two piston and rod assemblies.  This cancels there weight out when running.  When I took a maching class we learned all this and it even holds true on some 6 and 8 cylinder in-line engines which are designed like that to make balancing of the crank easier and it will also make a smoother running engine.
We balanced all kinds of crankshafts as a requirement to pass the class and the v-configuration engines had to have the piston rod assembly weighed very accurately and the proper counter weights of the exact weight were added in place of the piston/rods on the journals.  Every four cylinder was balanced without counter weights  because that is just how it works.  The only thing to be aware of is that each piston/rod assembly is weight matched to each other exactly.  I took a spare crank from a 550 in and put it on the machine.  It was perfectly balanced without counter weights.  I will probably do the same to the crank I am going to run with this combo.  I wouldn't want to throw in a bum crank and think the thing came apart for other reasons.
Adding weight to a crank is expensive but when you have to add Mallory metal to it because adding steel isn't enough, it puts a whole new meaning to expensive.
